Author Topic: Autowash...  (Read 3629 times)
Offline ifti
Autowash...
« on: 23 April 2009, 20:18 »
Is it supposed to really foam up???
I used it for the first time this past weekend. Although it washed the car fine, it didnt foam up like a 'shampoo'.......
Offline Guy
Re: Autowash...
« Reply #1 on: 23 April 2009, 22:28 »
yes... i use it with the pressure washer to fill the bucket and 5ml produces more foam than water
if you're filling the bucket of suds by tap then vigourously agitate the water as you fill it  :cool:
you won't need more than 5ml (teaspoon)
Offline Conker
Re: Autowash...
« Reply #2 on: 24 April 2009, 08:18 »
Guys right - I fill from the tap and you need to give it a damn good thrashing to get the suds going (probably because of how concentrated the soap is), but once you've done that you get loads of lovely slippery suds!!  I use a clean paintbrush to really whip it up.
Offline ifti
Re: Autowash...
« Reply #3 on: 24 April 2009, 08:31 »
yes I did fill by tap - next time I'll use the garden hose on the spray setting, which should mix it up nicely as thats pretty forceful.
Thanks.
Offline stealthwolf
Re: Autowash...
« Reply #4 on: 24 April 2009, 19:56 »
You don't need to go after lots of suds to clean the car - you just need to make sure it's adequately mixed. I always pour the shampoo into the bucket first and then fill it with water. Usually enough to get an adequate mix.
Offline ifti
Re: Autowash...
« Reply #5 on: 24 April 2009, 20:45 »
That makes complete sense, whereas idiot here did it the other way round and wondered why it still looked like plain water! lol
How embarrassed I am right now! rofl!
Offline stealthwolf
Re: Autowash...
« Reply #6 on: 25 April 2009, 11:39 »
If you watch some detailing videos, there are professionals out there who put the shampoo in after filling the bucket with water. They then gently agitate the water.
Like I said, you're not after suds, just a good mix of the shampoo and water.
Offline Conker
Re: Autowash...
« Reply #7 on: 27 April 2009, 12:52 »
I think suds help if your washing a fairly dirty car, e.g. if you haven't pressure washed it first, as the foam will help lift dirt off and keep it away from the bodywork.
Offline stealthwolf
Re: Autowash...
« Reply #8 on: 27 April 2009, 20:25 »
True but that's why I wash the car two or three times over. Regardless, I put the shampoo in the bucket first and get loads of suds. Plus DJ BTBM produces lots of suds and is very slick too.
