Author Topic: VAG Com - Hall Sensor....?  (Read 4552 times)
Offline Shady Pioneer
  • graphic designer.
Re: VAG Com - Hall Sensor....?
« Reply #10 on: 22 April 2009, 17:11 »
I could be wrong but i think that code can be flagged if the dizzy isnt timed up right? Maybe?
Any idea how I find out if it's timed up right or not? I'm a noob in the mech department lol!
« Reply #11 on: 23 April 2009, 09:38 »
what engine code is it?
  • graphic designer.
« Reply #12 on: 23 April 2009, 10:04 »
« Reply #13 on: 23 April 2009, 11:16 »
nothing i have covers the adz so i cant really say for sure :(
  • graphic designer.
« Reply #14 on: 23 April 2009, 11:23 »
Okay man, not to worry, what other engines from the MK3 do you have? Something on a 1.8 or 1.6? Even a GTI what do they say?
« Reply #15 on: 23 April 2009, 12:42 »
well the early 2.0 8v GTI 2e engine you set up pretty much like a MK2 digifant GTI, the later ones and abf you set to TDC and the ECU does the rest. Not sure if either of these methods work on yours?
Offline slicksps
  • Web Design and now DIY mechanic for mkIII CL
« Reply #16 on: 23 April 2009, 12:47 »
I had this error code as a newbie too. After some research I found that if the engine is off, this error will come up as standard.
Sorry if I'm stating the obvious and you're not as dense as me :) but did you do it with the engine running?
If yes, ignore I even saved this post
« Last Edit: 23 April 2009, 17:44 by slicksps »
  • graphic designer.
« Reply #17 on: 23 April 2009, 12:56 »
No I didn't do that, I just had ignition on. You may have given me the greatest news ever :P I'll have to get it VAG Commed again with the engine running, if it still persists I'll be back for more info from you jonny :)
« Reply #18 on: 23 April 2009, 14:24 »
ahh yes, could well be this!
the abf engine crank sensor flags a code if you check it with ign off, but the adz doesnt have one so could be on to a winner there :)
  • graphic designer.
« Reply #19 on: 30 April 2009, 20:39 »
So good news! Nothing is wrong with my car  :laugh: :laugh: :laugh:
Tried VAG-COM again today with the engine running and the fault didn't show, tried again with only ignition on, fault was there, so must be what was mentioned earlier, cheers guys :)
