Author Topic: VAG Com - Hall Sensor....?  (Read 4551 times)
Offline Shady Pioneer
  • graphic designer.
« on: 21 April 2009, 20:52 »
Got an error about my (Hall) Sensor, dunno the code I'm afraid, something about a camshaft...doesn't sound good :(
Any ideas?
« Last Edit: 21 April 2009, 21:02 by Shady Pioneer »
  • graphic designer.
Re: VAG Com - Hall Sensor....?
« Reply #1 on: 21 April 2009, 22:16 »
Distributor cap? Or the sensor for it?
Offline Adam
« Reply #2 on: 21 April 2009, 22:24 »
Recalled the code for it -
1 Fault Found:
00515 - Camshaft Position (Hall) Sensor (G40)
16-10 - Signal Outside Specifications
Sorry again bud,
Down Hill From Here.
  • graphic designer.
« Reply #3 on: 21 April 2009, 22:25 »
Well as above, someone please put me out of my misery lol!
« Reply #4 on: 21 April 2009, 23:30 »
I think the hall sender is fitted to your Distributor.
  • graphic designer.
« Reply #5 on: 21 April 2009, 23:33 »
Why is it bad then? What would be causing it to come up as a fault?
« Reply #6 on: 21 April 2009, 23:37 »
If it has failed then it would or should show as a fault.
  • graphic designer.
« Reply #7 on: 21 April 2009, 23:42 »
Guess I better get on changing the sensor, any numbers or info I need to get a replacement? Guessing it's a loom or something?
« Reply #8 on: 21 April 2009, 23:45 »
Not sure to be honest.
Try: http://www.vagcat.com/ its free to join and very handy.
« Reply #9 on: 22 April 2009, 09:28 »
I could be wrong but i think that code can be flagged if the dizzy isnt timed up right? Maybe?
