Author Topic: Door Speaker Wiring!  (Read 13751 times)
Offline Len
« on: 20 April 2009, 23:23 »
How the heck do you get wires/cables through the door grommet thing!!! ???
Had a look this evening and you unscrew a big nut shaped plastic knob and pull out and there is this multipin connector!
Thought I could just thread wires through the big grommet thing but no way through!
So c'mon folks somebody out there must have  threaded wires through that area somehow!
Help!
« Last Edit: 24 April 2009, 13:31 by Len »
www.sas.org.uk
www.the-ace.org.uk
Offline Len
Re: Big Problem!
« Reply #1 on: 21 April 2009, 10:17 »
So where are the Audio experts when ya need em?
But its beginning to look like I need to drill some holes!  :cry:
www.sas.org.uk
www.the-ace.org.uk
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re: Big Problem!
« Reply #2 on: 21 April 2009, 11:46 »
Len,
I've not owned (nor even looked at) the grommets of a mk3
Get some pics up and I'll see if I can be of help.
The greatest leveller of them all - the Carousel
Offline Len
Re: Big Problem!
« Reply #3 on: 21 April 2009, 12:07 »
Posted in Mk3 section too and kells has told me what he did.
Basically same as the conclusion I had come to in that you have to bypass the grommet/boot thing and drill seperate holes!
No way through that multipin socket! :sad:
Hopefully Billy can sort me some flexible cable protection!  :wink:
www.sas.org.uk
www.the-ace.org.uk
Offline bratty
Re: Big Problem!
« Reply #4 on: 21 April 2009, 12:11 »
dont sound good, i wanna re-wire my door components and looked at that gromit thinking f**k that :S
Quote from: Conker on April 28, 2009, 00:32
OMFG. Please tell me you were banging your willy on the keyboard and these were the random words that appeared.
Offline Len
Re: Big Problem!
« Reply #5 on: 21 April 2009, 12:16 »
Yea mate its a nightmare when you pull it apart!
I mean I guess there are some spare pins and if you were a whizz with electrics might be able to sort it but for me no way!
prefer to have wires straight from amp to speaker without joints anyway!
www.sas.org.uk
www.the-ace.org.uk
Offline bratty
Re: Big Problem!
« Reply #6 on: 21 April 2009, 12:24 »
same here :)
Offline Len
Re: Big Problem!
« Reply #7 on: 21 April 2009, 12:58 »
Sounds good already with just the Alpines in the dash.
Will be even better tonight when I fix the rear offside tweeter and fit the crossovers!
www.sas.org.uk
www.the-ace.org.uk
Offline bratty
Re: Big Problem!
« Reply #8 on: 21 April 2009, 13:15 »
i havent even looked at mine yet, there running straight of my alpine head unit which is 200 watts and they sound pretty awesome as it is, but when i get my new power cable in for my sub amp and can crank that right up ill need to amp my comps :)
Offline wampablo
  • 2nd mk4
Re: Big Problem!
« Reply #9 on: 23 April 2009, 12:52 »
what i usedto do is this take the plug out chances are there will be some spare holes that havnt been filled with pins just drill them out aand thread tha wires thru drill the same ones on theconnecting plug job done easy i di my cavalier like that yeasr ago never had any problem with it
