Author Topic: mk 3 gti cutting out worse in rain  (Read 2664 times)
Offline gandc m
« on: 29 July 2004, 19:45 »
 :( could anyone help, ive got a mk3 2.o l 8v gti that keeps cutting out when clutch goes down . this seems to get even worse in rain cleaned throttle body and replaced breather hoses dont know what to try next any ideas !
nogama3
Re:mk 3 gti cutting out worse in rain
« Reply #1 on: 30 July 2004, 14:52 »
could be your ecu's on its way oout, have encountered similar problems on my bor's mk2, replaced 2 ecu's so far, problem goes away for 2-3 months before returning. Last ECU has lasted 6 months +. If you have a mate who has a mk3 8v gti, then just swap the ecu's to see if the problem goes away before spending lots of money.
Offline gandc m
« Reply #2 on: 30 July 2004, 22:11 »
cheers for advice on ecu just had it on a diagnostic machine and thats saying theres no probs. then he tried it on a fault code reader and no fault codes had been recorded. The guy suggested giving the throttle body another right good clean as they can supposedly be quite tempramental.When i replaced each of the breather hoses though it stopped it cutting out for a week or two then it started to do it again - its weird!
golfvr6
« Reply #3 on: 30 July 2004, 23:51 »
change the fuel pump and ecu relays.
it seems to work for everyone else  ;)
Offline gandc m
« Reply #4 on: 31 July 2004, 22:45 »
changing ecu relays and fuel pump is probably next on my list - the cars worth spending a few quid on coz when its not cutting out it drives mint i just hope its nothing too serious but if it was, surely diagnostic machine would have picked it up wouldnt it !  phoned around and can get a fuel pump for ?40.00 plus vat so thats not too steep i dont think needless to say i never got a quote from v dub dealer theyll probably charge the earth !
Offline Len
« Reply #5 on: 02 August 2004, 09:19 »
Just change the relays first.
They are approx ?8 for the ECU and ?12 for the fuel pump relay.
Can check em first like i was told by running the car to warm then taking out the relays to see if they are warm or cold. If cold then change them.
www.sas.org.uk
www.the-ace.org.uk
Offline gandc m
« Reply #6 on: 02 August 2004, 21:28 »
Thanks for that tip will try it tomorrow and see what happens but i still cant figure out howcome it gets worse in rain unless its just coincidence !
Offline insane
« Reply #7 on: 05 August 2004, 00:42 »
Hi mate
wow! i had same problem for ages aswell
thought i was only one
always cut out when changing down gear into 2nd / 1st
and loads worse in rain! and even more so at night in rain, with stereo , wipers etc going
i did everything
full service. nothing!
injection cleaner. nothing!
other cleaners! nothing!
oil flush, nothing!
diagnostic machine, nothing!
then car mechanic cleaned my throttle body for me good and proper!
SORTED!!!!!!!!!!!
 ;D
So i would adivse a good old cleaning again!
hope you sort it mate!
cheers
Ben
:D
Offline mozzer
« Reply #8 on: 10 August 2004, 09:28 »
Yeah been there sorted that. I got the mk3 2.0 8v gti(?). Its the THROTTLE CONTROL VALVE it will need to be cleaned out properly matey. I took mine to VW to sort as it was getting dangerous when and where it kept cutting out. Took them two days to find the problem. Nothing shows as being wrong when plugged to the diagnostic machine. Eventually they saw an irregular tick over and replaced it at a cost of ?260... that was without labour charges they didnt charge labour as it took them so long to find the problem. thank god for that they charge ?56ph.
