Author Topic: help with vag com codes  (Read 1713 times)
Offline bully85
« on: 18 April 2009, 20:25 »
how the devil do you get this to work?i put it in the laptop and it installs put doesnt seem to find it when i plug it in?its runin on vista am i missing anythin
« Last Edit: 18 April 2009, 21:54 by bully85 »
Offline northeast_gti-t
  • "1.8T AGU"
Re: vag com
« Reply #1 on: 18 April 2009, 20:27 »
have you changed the com port settings so the lead corresponds to the setting on vag com? and you have to run it as administrator to  :wink:
2000 Mkiv GTi 1.8T AGU
Offline bully85
Re: vag com
« Reply #2 on: 18 April 2009, 20:31 »
com port?in vag com sit it to usb if ya get me?
  • "1.8T AGU"
Re: vag com
« Reply #3 on: 18 April 2009, 20:45 »
have you installed a virtual com port that vista needs to run the usb if not you have to tweak it it does work  :wink:
  • "1.8T AGU"
Re: vag com
« Reply #4 on: 18 April 2009, 20:47 »
try this if you haven't already downloaded it http://www.ftdichip.com/
Offline jonnyturbo
Re: vag com
« Reply #5 on: 18 April 2009, 20:52 »
lol matt when are we getting VAG com lol  :cool:
Offline Steve_PD
Re: vag com
« Reply #6 on: 18 April 2009, 20:53 »
this is for xp but its pretty much the same as vista  :undecided:
Quote from: Steve_PD
It told you how to change which com the lead was on in windows, buy going to control panel - system - device manager - ports, and then changing the port the vag com lead is connected to to com 2, by right clicking the lead goto - properties - port settings - advanced settings - then change the port to com 2 and ok.
Then try it in vag-com on com 2
You also got to be in administrator to run it
  • "1.8T AGU"
Re: vag com
« Reply #7 on: 18 April 2009, 20:58 »
as steve says  :wink: thats what i have done to get it to run on vista  :wink:
Offline bully85
Re: vag com
« Reply #8 on: 18 April 2009, 21:31 »
done it think i got sum promblems which numbers are the fault codes? controller?component?coding?shop?
  • "1.8T AGU"
Re: help with vag com codes
« Reply #9 on: 19 April 2009, 00:49 »
your fault codes will be highlighted in the box as a series of numbers etc
