Author Topic: Starting problems  (Read 3015 times)
Offline JonMk1Cab
Starting problems
« on: 28 July 2004, 00:00 »
Hi, new Golf owner (first time now converted?) however, the car is just about to go on the road and I have problems starting.  If it doesn't start first time and I give it some gas it then wont start at all.  Its a Mark 1 GTi Cabriolet (Y plate).  Is this normal?
Thanks
Offline 8valvesgood
Re:Starting problems
« Reply #1 on: 28 July 2004, 00:06 »
hello
does the weather affect its starting? is it worse on a hot day or a cold day?
when its started what is the idle speed readout?
You can't polish a turd
Offline JonMk1Cab
« Reply #2 on: 28 July 2004, 00:21 »
The car's beem in a lock up, so not rewally affectyed by weather.  It had a blast about 2 weeks ago, otherwise I have been finishing off the re-build of the body/fitting hood.  Got the battery on charge over night, however has a boost facility, which still did not get the engine started.
Does depressing the accelerator once  make these engines flood?
Offline 8valvesgood
« Reply #3 on: 28 July 2004, 00:28 »
only if your fuel mixture is wrong you can adjust this will an allen key its the metering head
increase the tick over a notch you should rarely have to dip the peddle to start it.
Offline JonMk1Cab
« Reply #4 on: 28 July 2004, 00:38 »
Thanks,
I'll see how I get on Tomorrow.
Offline eyeletboy
« Reply #5 on: 28 July 2004, 01:00 »
is it flooding?can you smell petrol?
golfvr6
« Reply #6 on: 28 July 2004, 09:34 »
Maybe leaky injectors and/or cold start valve.
Try leaving the cold start valve unplugged.
Speedydub
« Reply #7 on: 28 July 2004, 09:36 »
i had a prob similar with my mk1...the carb was flooding, that was why. apparently a former owner had replaced the carb with an earlier model that didnt have a return  :-\
or something like that anyway...
Offline JonMk1Cab
« Reply #8 on: 28 July 2004, 22:20 »
Had the battery on charge over night, cleaned all the plugs.
Have disconnected the cold start valve previously, however when re-connected it shot up to 3500rpm.
Think it just needs a good tune - will check the hose tomotrrow to see if it is split.
Any other ideas?
Offline JonMk1Cab
« Reply #9 on: 30 July 2004, 23:35 »
Seems to be starting a lot better since the battery has a full charge.
Took it for a re-test of the MOT, passed  ;D (since I had already done all the work),  Now just need the V5 to arrive to get Tax
