Author Topic: compression test advice  (Read 15199 times)
golfvr6
Re:compression test advice
« Reply #10 on: 27 July 2004, 00:06 »
When i've done it before, i took the ht lead off that connects the coil and the dizzy, remove the lead completely, no problems.
Then also remove the fuel pump fuse.
Offline Deefadog
  • Mk2 16V (November 89)
« Reply #11 on: 27 July 2004, 08:36 »
Why the fuel pump fuse, does this stop the car from becoming flooded?
Offline Gambit
« Reply #12 on: 27 July 2004, 09:41 »
aye
golfvr6
« Reply #13 on: 27 July 2004, 09:55 »
Yar.
If you don't take out the fuel pump fuse then you will get rather high compression, as the cylinders will flood with fuel  :D
Offline Deefadog
« Reply #14 on: 27 July 2004, 12:42 »
Thanks, i'll do it this week, any ideas what the pressure should be on my MK2 16V?
Offline Gambit
« Reply #15 on: 27 July 2004, 16:36 »
std should be about 180, goodun's more towards 200+
« Last Edit: 27 July 2004, 16:42 by Gambit »
Offline Deefadog
« Reply #16 on: 27 July 2004, 19:58 »
Thanks i'll let you know when i do it, probablly friday!
take care
Offline Deefadog
« Reply #17 on: 30 July 2004, 17:46 »
Right good news here are the compression test results (I am working from left to right as I don't know which are which)
Cylinder1: 185 psi
Cylinder2: 190 psi
Cylinder3: 185 psi
Cylinder4: 185 psi
The second one was slightly higher as you can see, but not by much.
So what next? If this is a good result on a car that has done 183000 miles, where else should I look for the burning oil? remember it only appears when the engine is up to running temp and is idling, i can drive for 10 minutes or 2 hours, pull up and let the car idle, at first the exhuast is clear then after about 1 minute the smoke apears, not bellowing out but enough.
Any advice would be much appreciated as always
Offline mk1
« Reply #18 on: 30 July 2004, 21:34 »
Compressions are bang on, oil consumption is probably from the valve stem seals.
Steve.
golfvr6
« Reply #19 on: 30 July 2004, 23:50 »
Have you cleaned the breather hoses?
