Author Topic: compression test advice  (Read 15196 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 26 July 2004, 15:01 »
Hi all i just bought a compression tester from Halfords, now I need to get the car to running temp and then disconect the coil, how do I disconnect the coil? I don't know where it is i am really stupid :) Is it where the middle ht lead comes out of?
A pic would be great :)
Also when I do the readings what should they be?
Offline 16v Matt
Re:compression test advice
« Reply #1 on: 26 July 2004, 15:28 »
Yes mate, its the middle one. Make sure the disconnected lead is'nt touching anything or ANYONE when you crank it. Not sure what's good but my valver was 10bar in all cylinders. Would be interested to see what you get. Its important that all the cylinders have a simlar compression too.
Cheers,
Matt.
Offline Deefadog
« Reply #2 on: 26 July 2004, 15:35 »
Cheers, so it's the middle ht lead from the coil I disconnect, yes and rap some insulating tape around it to keep everything safe? any more tips when doing this?
Offline 16v Matt
« Reply #3 on: 26 July 2004, 15:53 »
You might want to wait for expert :-\  But thats all i did. Just Take one spark plug out at a time screw the compression tester in & crank the car for a few seconds take the reading, put the spark plug back & move on to the next one.
Offline 16v Matt
« Reply #4 on: 26 July 2004, 15:55 »
Oh & i think there is wet & dry compression tests. I'm sure someone will tell me if i'm wrong, but the above is a dry test????  Not sure what the wet test tells you, someone here will defo know. Cheers.
Offline Deefadog
« Reply #5 on: 26 July 2004, 16:42 »
Thanks Matt
Offline mk1
« Reply #6 on: 26 July 2004, 18:16 »
I would not leave the coil lead open circuit as this will cause a massive voltage build up and can damage the ign amplifier :o. Recommend disconnecting the low tension wires to the coil, and when cranking the engine hold the throttle open to give the most accurate reading.
Steve.
Offline Deefadog
« Reply #7 on: 26 July 2004, 18:31 »
Thanks
Is this the coil?:
And if it is I have a spade free as you can see, should I have something connected here?
MK1 -  When you say "Recommend disconnecting the low tension wires to the coil"
Are these the other spade connector to the coil?
Offline mk1
« Reply #8 on: 26 July 2004, 22:14 »
Yup, thats the coil. (nice picture ;))
Spare terminal on the coil is OK, disconnect either side and it will be OK.
Steve.
Offline Deefadog
« Reply #9 on: 26 July 2004, 23:17 »
Cheers mate, funny thing is when I came home today and let my car run on idell for a few minutes(as I always do, since ot started smoking) it did not smoke, but my mileometer stoped working, but rev counter was fine, if it aint one thing it's another :)
Happy days :)
