Author Topic: No Memory  (Read 3271 times)
Offline Onge
No Memory
« on: 26 July 2004, 10:53 »
Any ideas,
I have just fitted a kenwood KDC-3021 cd/radio unit into my 1995 Golf Gti. Problem is it is not storing any of the radio stations or settings.
I fitted the unit myself, with a halfords supplied cable assembley - just clicked the connectors together.
Blue MK2
Re:No Memory
« Reply #1 on: 26 July 2004, 12:03 »
Not sure on kenwood sterios but on my pioneer unit i connected the red and yellow wires together by the connector pins.
Offline gibson
Re:No Memory
« Reply #2 on: 26 July 2004, 12:14 »
have had the same problem before many times and i solve it by either swapping the yellow/red conectors around (eg yellow to red and vice versa instead of yellow to yellow and red to red) or like previously said put the red and yellow together, but this will make your headunit permanenty on rather than switchingon from the ignition. Hope that helps
Offline Onge
Re:No Memory
« Reply #3 on: 26 July 2004, 13:57 »
Cheers Gibson ;D
I'll give it a go.
It is weird that the cable assembly supplied to connect the kenwood to the VW does'nt have the correct wiring in the first place.
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re:No Memory
« Reply #4 on: 26 July 2004, 14:17 »
^^ the reason for this is that although most car manufacturers have adopted the ISO connector to terminate their stereo wires, they can't quite agree which should be the perm. live and which should be the switched live, hence the need to swap the wires over mid-loom in some cars.
Swap them over and you'll be cool and the gang.
The greatest leveller of them all - the Carousel
Offline gibson
Re:No Memory
« Reply #5 on: 26 July 2004, 16:16 »
no problem,  s11eps is right with what he says. I remember the first time it happended to me - drove me bloody mad for ages
Offline AdamB
  • The Perfect Storm
Re:No Memory
« Reply #6 on: 26 July 2004, 17:05 »
I have memory problems too, usually down to JD!
But S11EPS is right, I had this problem with my Kenwood system and Cab, and have experienced it on other VW too. Its as simple as swapping the ignition live and permenant live wires around.
I don't own this anymore - I just can't be arsed to change the picture
Offline gibson
Re:No Memory
« Reply #7 on: 26 July 2004, 22:56 »
ah yes the JD, cant beat it....
Offline Onge
Re:No Memory
« Reply #8 on: 28 July 2004, 09:03 »
Swapped over the red and yellow.........it's sorted !!!!!
Cheers Guy's  ;D
