Author Topic: wheel issue  (Read 3230 times)
Offline squires
wheel issue
« on: 09 April 2009, 20:17 »
for some reasonon my mk2 gti 8v the o/s/f wheel sticks out the arch by about an inch, whilst the nearside sits in the arch, what could be causing this? the wing is straight so im guessing its something else, help much appreciated as i dont want a £200 fine off the old bill for being "dangerous" i will get picks 2moz when its daylight.
Offline Ben Lessani
Re: wheel issue
« Reply #1 on: 09 April 2009, 20:21 »
Could be anything!
Sounds like a shunt has damaged the rear subframe.
Offline Dan34
  • VTEC Powerzzzz
Re: wheel issue
« Reply #2 on: 09 April 2009, 20:44 »
Could be anything!
That sounds bad  :lipsrsealed: my car is the same as squires, never really thought much off it really, my car tracks straight and has got throught mot's ect
should i be worried too lol
Dan
Offline squires
Re: wheel issue
« Reply #3 on: 09 April 2009, 21:06 »
hmmm il have my head under it 2moro, mine also drives fine and got through mot, i only noticed recently as i changed the wheels
Re: wheel issue
« Reply #4 on: 10 April 2009, 11:41 »
look at the car from the front, check if the wheels are at an angle when straight ahead. stock the mk2 should have a little -ve camber, so wheels look like this (not so angled but you get the idea):
On my GTI it had obvioulsy been kerbed and shock/bone replaced on passenger side, had loads of positive camber and looked like this:
If yours is the same that could explain it! Can just about make it out in tis pic, tho wheel is turned slightly
Offline squires
Re: wheel issue
« Reply #5 on: 10 April 2009, 15:42 »
heres some pics
its been raining all day so will hopefeully get to look at it after work 2moro
Offline Dan34
  • VTEC Powerzzzz
Re: wheel issue
« Reply #6 on: 10 April 2009, 15:44 »
that is pretty bad i dont think mine sticks out like that, il go get some pics now
Dan
Offline JC
  • Back in the North.
Re: wheel issue
« Reply #7 on: 10 April 2009, 15:45 »
have you had the wheel off ?  there isnt a spacer on one side is there  :laugh:
Offline squires
Re: wheel issue
« Reply #8 on: 10 April 2009, 15:47 »
na no spacers, there all the same offset to
Offline Ant
Re: wheel issue
« Reply #9 on: 10 April 2009, 15:51 »
And the same width, looking front on the n/s tyre seems to have a stretched look while the o/s looks square, might just be the picture though.
