Author Topic: Temp sender locations  (Read 2528 times)
Offline Dan34
  • VTEC Powerzzzz
« on: 05 April 2009, 18:54 »
Right quick question here, where abouts are the coolant temp senders located (one for clocks and blue ECU one) ive attached a pic and i think the one ive ringed is the one for the clocks but im not sure where the ECU one is, anyone help?
Thanks
Dan
Offline Dan34
  • VTEC Powerzzzz
Re: Temp sender locations
« Reply #1 on: 05 April 2009, 21:34 »
anyone.....
its a gti 8v digi
Dan :smiley:
Offline JC
  • Back in the North.
« Reply #2 on: 05 April 2009, 21:39 »
sos mate - valver owner  :cool:
Offline tyler
« Reply #3 on: 05 April 2009, 21:42 »
i think the one for the clocks is the lower one down and the top one for the ecu best way is get it warm and disconnect each one and see if the temp gauge stops working  :cry:
corrado 16v lowered,leather,grill,oz route,m3 lights polished engine,
mk1 golf cabby not alot done but in primer
Offline Dan34
  • VTEC Powerzzzz
« Reply #4 on: 05 April 2009, 21:43 »
surley if i disconected them when hot coolant will pee everywhere lol?
Dan
Offline Mk2George
« Reply #5 on: 05 April 2009, 21:48 »
No just disconnect the wire, dont take the sensor out. For what its worth the black one is for the coolant temp (gauge in the car) not sure if that helps
« Last Edit: 05 April 2009, 23:06 by Mk2George »
Offline tyler
« Reply #6 on: 05 April 2009, 21:49 »
just the wires bud  :wink:
Offline Dan34
  • VTEC Powerzzzz
« Reply #7 on: 05 April 2009, 21:50 »
aaaaah now i get ya lol  :grin:, yeah ive been reading about it the ones for the clocks can be eitehr black or white so sorted that one out  :smiley: but where is the ECU one, surly it isnt the little one below it? i would have thought it would be the same size as the clocks one  :huh:
Dan
Offline Steve_B
« Reply #8 on: 05 April 2009, 22:04 »
Looks like you've got a diffreent set-up to mine (8v digifant). I've got black and blue sensors in the housing bit where you've circled.
Offline Dan34
  • VTEC Powerzzzz
« Reply #9 on: 05 April 2009, 22:33 »
hummmmm im pretty sure mines a digi 8v PB engine code, wheres rubjohny when you need him lol
Dan
