Author Topic: Temp sender locations  (Read 2527 times)
Offline Mk2George
Re: Temp sender locations
« Reply #10 on: 05 April 2009, 23:17 »
This was the thread I started when I had an 8v, might be of some use
http://www.golfgtiforum.co.uk/index.php?topic=54939.msg425658#msg425658
Offline Dan34
  • VTEC Powerzzzz
« Reply #11 on: 05 April 2009, 23:21 »
cheers, im confused now as to where my ecu sender is  :sad: . . . . . .
Dan
Offline Mk2George
« Reply #12 on: 05 April 2009, 23:23 »
Why, does yours look different to that?
Offline Dan34
  • VTEC Powerzzzz
« Reply #13 on: 05 April 2009, 23:25 »
yeah the nears sender is smaller and only has one wire going to it i think
Dan
Offline Steve_B
« Reply #14 on: 05 April 2009, 23:28 »
Is there only 1 sensor there? Looks like it has 2 sets of wires coming off it. Maybe a previous owner has done rigged something up?
Offline Dan34
  • VTEC Powerzzzz
« Reply #15 on: 05 April 2009, 23:29 »
yeh from what i can remember and from the pic there is only one sender, so maybe its been tinckered with or mines got it elsewhere not too sure
Dan
« Reply #16 on: 06 April 2009, 08:30 »
large 2 pin sensor is for ecu, single pin small one is for dash gauge.  The dash one is incorrect, it should have a black colar, I can see yours is white. White colar one is for MFA oil temp.
early digifants have a metal water flange with threaded sensors, late ones have plastic housing with push fit.
Offline Dan34
  • VTEC Powerzzzz
« Reply #17 on: 06 April 2009, 09:31 »
Thanks do you know the etka codes for the ecu and dash one for mine? and is the sender ive circled in my pic definetly the ECU one?
Thanks
Offline shikta000
« Reply #18 on: 06 April 2009, 12:47 »
hello ... my ecu sender is the same as yours ... vw still do them , if you look in the ekta code section of the forum i seem to remember when i bought my new ecu sender i put up the code there.
« Reply #19 on: 06 April 2009, 15:10 »
yes it is the ecu sensor:
035 919 369 M - 32+VAT
