Author Topic: 16v calipers  (Read 1160 times)
Offline beechymonza
  • mad beech
16v calipers
« on: 05 April 2009, 17:35 »
been readin what the other geezer was sayin about hand brake cables, mines the same, sh!t, tried 2 free it this mornin, no luck, mot on thurs, does the mk3 caliper fit straight on or i gotta modify stuff, is it any mk3 caliper or gotta be of gti :undecided: :undecided:
No guts No glory,
Offline H981CVV
Re: 16v calipers
« Reply #1 on: 05 April 2009, 17:45 »
all the mk3 gti rears fir straight on, they look quite similar to mk2 ones but have different internals, im not sure about the other mk3 cars and if its just the gti's but if it has rear discs there probably the same
Offline sidecarphil
Re: 16v calipers
« Reply #2 on: 05 April 2009, 17:53 »
what hoses do you need if you want to fit the MK4 calipers ???
VeeDubGTI16v
Re: 16v calipers
« Reply #3 on: 05 April 2009, 17:53 »
goodridge make conversion hoses for the mk4's
Offline Ben Lessani
Re: 16v calipers
« Reply #4 on: 05 April 2009, 18:38 »
Early MK3 calipers are the same as the MK2 ones. You need late spec ones. You can tell they are right because the cable mounts on the underside, not the top.
The MK4 calipers are the same as the MK3 ones, just alloy (no rusty). They have a banjo fitting, so need a hose conversion kit. If you're going from drums, you'll need the 4 hose, from disks you'll need the 6 hose IIRC.
For both of them you need the late spec handbrake cables, pre 88 cables won't fit right.
You can mount them the wrong way round (left on right / right on left) and retain the pre 88 cables, but the bleed nipple will be on the bottom - so you'd need to remove the calipers to bleed them.
Re: 16v calipers
« Reply #5 on: 06 April 2009, 08:52 »
No thats early/late MK2 spec you ID with the handbrake cable, to ID early/late MK3 check for a handbrake spring. if there is one they're early MK3 ones, which are exactly the same as late MK2.
MK4 ones still corrode and sieze up, so best to paint them. the bleed nipples also sieze in thanks to metal corrosion that occurs when 2 different metals are in contact (forgot what its called again)
Nope not quite that easy, cant fit post-87 handbrake cables to a pre-87 car, they're miles too short.  What you have to do to fit post 87 calipers to a pre-87 car is flip them upside down as you say.
Offline beechymonza
  • mad beech
Re: 16v calipers
« Reply #6 on: 06 April 2009, 17:40 »
mine is an early 88 16v with the smaller discs on front, are the backs the same size as mk3 gti,  :rolleyes:
No guts No glory,
Re: 16v calipers
« Reply #7 on: 07 April 2009, 10:08 »
discs from MK2 and MK3 are the same size, just 4/5 stud.  the calipers on the pre87 have smaller pistons though
