Author Topic: What do you all use to dry your freshly washed cars with ?  (Read 17043 times)
Offline Rhyso
Re: What do you all use to dry your freshly washed cars with ?
« Reply #40 on: 02 June 2009, 13:48 »
When you say sheeting, what do you mean? I normally give it a blast with the pressure washer and push as much of the standing water as possible off with that but there is usually still some on the flat surfaces etc...
don't use the pressure washer for this - just use the hose (without any attachments) and literally let the water fall onto the car
a carefully prepared / waxed surface will 'sheet' the water away leaving either tiny droplets or next to no water on the surface meaning no unsightly marks if the water drys quickly and less need for the use of a drying towel  :smiley:
Offline jaydubveedub
« Reply #41 on: 04 June 2009, 13:35 »
OK this is a stupid question but what is the difference between something like the Sonus and a synthetic chamois?
I've been using AG Aqua-dry for years and it seems very good.
Would something like the Sonus towels be better for my paintwork?
Bear in mind I wax after every wash anyway.
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
« Reply #42 on: 15 June 2009, 13:50 »
Bought the Sonus. It's very good.
