Author Topic: Sub + Amp installation in Mark 4 Golf  (Read 3246 times)
Offline m19ads
« on: 04 April 2009, 21:10 »
Hi
Having just purchased my golf I am keen to install my sub and amp and a new headunit of course as already missing having it, even though only been a couple of weeks lol!!
I was just wondering if anyone can advise me on the best place to route the cables?  Obviously I need to get through the bulk head and into the engine bay with the power cable but is there a good path to take?  Also is there a good place to run the cables from the head unit to the boot?  Obviously I just want it all in nice and neatly and discretely!
If anyone can advise I would be very grateful, also if any one has any pictures too then even better!!  The other thing I wondered was do people frill through the battery cover to get to the positive terminal?
Sorry for all the questions but as said would really appreciate any help!
Thanks in advance
Ads :smiley:
On Order Golf GTI 5 door Tornado Red Performance Pack 19inch Santiagos Build week 11/4 currently in transit..........
2014 VW Touran SE
2004 BMW 325CI Convertible
2005 Golf GTI 5 door Black (favourite car to date)
2006 VW Touran Sport
2002 Golf GT TDI 130
Loads of non VW stuff that I don't want to confess too!!!
Offline troublestarter
Re: Sub + Amp installation in Mark 4 Golf
« Reply #1 on: 04 April 2009, 23:30 »
to get the power cable into the car you need to do several things
1 remove the scuttle panel plastic on the passenger side of the windscreen
2 remove the pollen filter cover underneath the scuttle panel
3 remove the centre console
4 remove the glove box
when the glove box has been removed pull the white foam material upwards and look up to the top of the bulkhead and you will see a grommet this is where you need to run your power cable through
the power cable will also nee to be routed through the bent plastic trim leading to the battery(the cover unclips from this)
you will not need to drill the battery cover
run all the rca's and remote cable down the drivers side
i will post some pics tomorrow
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline m19ads
« Reply #2 on: 05 April 2009, 09:42 »
Thats great thanks a lot!  I will look forward to seeing the pictures! :smiley:
2014 VW Touran SE
Offline m19ads
« Reply #3 on: 07 April 2009, 19:21 »
Well just got my wiring kit so will be looking o install in the next few days so if any one else has any advice on the cable routes or anything else then please do tell  :smiley:
2014 VW Touran SE
Offline Khare
  • The bear that khares
« Reply #4 on: 07 April 2009, 19:28 »
I too was told to keep power and RCA cables away from each other, interferance or something. But, when it came to doing it, i just ran all the cables together as its so much easier. I ran them down the passanger side, under the carpet, in the sill and up the dash for RCA and remote cable and then through bulkhead for +ve cable.
Offline JC
  • Back in the North.
« Reply #5 on: 07 April 2009, 19:34 »
what Mk of golf ?
but yeah, wot the rest said, i run all my cables down one side together ( power, sub feed etc etc )
Earth lead is as SHORT as posbile from the amp to an existing Earth point in the boot  :cool:
Offline m19ads
« Reply #6 on: 07 April 2009, 19:37 »
Its a mk 4....
2014 VW Touran SE
Offline JC
« Reply #7 on: 07 April 2009, 19:39 »
cant help with getting thru the firewall, but there might be a rubber gromet spare, and i run everything down the PASSENGER side, lessuse than the drivers in my car as the wires run under the kick trim panels  :wink:
Offline dTEA
  • back in an MK5
« Reply #8 on: 17 April 2009, 11:49 »
there is a grommet that you feed through just to the left of the passenger wing...you need to remove the pollen filter to get to it tho...that feeds nicely down to the passenger footwell...you might need to remove some of the foam protection from its clips in the footwell to get your hands to the carpet...
Edition 30 / T5 T32 Kombi
Offline m19ads
« Reply #9 on: 17 April 2009, 16:48 »
nice one thanks for that, was going to do it last weekend but when and got appendicitis lol so going to be a few weeks till I can get out and do it now, will update when I have done it!
2014 VW Touran SE
