Author Topic: What have you done to your Golf today?  (Read 1113337 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: What have you done to your Golf today?
« Reply #6920 on: 28 June 2014, 22:11 »
Fitted the newly painted mirror and glass,replaced the sump pan and oil pick up pipe and cleaned up around the engine from previous oil leakage,good thing i replaced it as the drain plug threads were fcuked!  :sad: found also the dogbone bush is also knackered so ordered a powerflex one,washed it and painted the lower grille vents should be fitted tomorrow  :smiley:
2000 Mkiv GTi 1.8T AGU
Offline clancy
« Reply #6921 on: 29 June 2014, 16:14 »
De wipered the mk3
Before
After
MK3 GTI 16v
VW BUSH
« Reply #6922 on: 29 June 2014, 20:44 »
Filled it to the roof with garden crud and ran it to the dump
Offline baka
« Reply #6923 on: 30 June 2014, 16:19 »
Got it back from the body shop! :laugh:
After having to drive a bloody Yaris for a week.:sick:
Offline viperjsy
« Reply #6924 on: 03 July 2014, 21:34 »
modified my engine cover to fit over the catch can pipes
  • "1.8T AGU"
« Reply #6925 on: 03 July 2014, 21:59 »
Fitted my powerflex dogbone mount bushes
Offline viperjsy
« Reply #6926 on: 04 July 2014, 14:11 »
replaced the dip stick tube
  • "1.8T AGU"
« Reply #6927 on: 04 July 2014, 22:07 »
Fitted two new top mounts and bearings and droplinks certainly makes a difference  :smiley: old ones were at least 10mm above the plate now they sit flush another job done
Offline Mr_Orange
« Reply #6928 on: 05 July 2014, 18:42 »
Oil + filter + new sump plug + polybush dogbone + welded exhaust bracket back on.
Bit of vibration at idle with the new mount, but need to go for a proper run to see how its changed things.
Got hold of some S3 rear calipers and bits. Started cleaning them up for lacquer and fitment ;)
Build thread clicky
Offline clancy
« Reply #6929 on: 05 July 2014, 20:15 »
Polished, waxed and put my bbs back together after their refurb :)
MK3 GTI 16v
