Author Topic: What have you done to your Golf today?  (Read 1113335 times)
Offline viperjsy
Re: What have you done to your Golf today?
« Reply #6900 on: 12 June 2014, 15:53 »
just wired up my oil temp gauge and fit and oil drain valve
« Last Edit: 14 June 2014, 11:42 by viperjsy »
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #6901 on: 13 June 2014, 22:19 »
Managed to crack my drivers mirror casing and glass last night  :angry: sorted a replacement and decided i would spray them black
Decided on wheel colour also
2000 Mkiv GTi 1.8T AGU
Offline viperjsy
« Reply #6902 on: 14 June 2014, 11:42 »
replaced this
  • "1.8T AGU"
« Reply #6903 on: 14 June 2014, 20:44 »
Prepped the rear spoiler and just primered,colour and laquer on tomorra  :whistle:
Offline Foreveryoungaus16v
« Reply #6904 on: 14 June 2014, 21:06 »
Quote from: brett link=topic=111980.msg2461702#msg2461702 date=14021726
36
Fitted new wheels  :smiley:
What you got on there now mate ?
Forged clubsports 7" and 9"
Car looks epic Mark
163 BHP (TSR POWER RUN)
VW BUSH
« Reply #6905 on: 14 June 2014, 22:49 »
Washed off some bird cack down the BP jet wash, found some new rust, ignore rattle from underneath
  • "1.8T AGU"
« Reply #6906 on: 15 June 2014, 22:21 »
Painted the rear spoiler,had to wash it as it was filthy then spent 2odd hours cleaning overspray that had bled through the loads of masking i applied  :sick: still its off now thank fcuk!
Offline clancy
« Reply #6907 on: 16 June 2014, 18:53 »
Done the airbox mod to my 16v. Sounds good :)
MK3 GTI 16v
Offline xAntiVenxm
« Reply #6908 on: 17 June 2014, 21:28 »
Not today but this weekend I..
Cleaned every single sensor, clamp, and electrical connection of the engine bay wiring loom with electrical contact cleaner
Replaced the ignition switch by way of pulling out steering column instead of the wheel. Was told it was easier but im not sure haha!
Solved the problem causing my project car to not run on its own without putting your foot down since I got it in 2011!! Was the ISV seized (thanks everyone for their help and suggesting this on my thread!)
Won some new wheels on fleabay for the old girl, mainly for the tyres but some audi pepper pots will do nicely for now while I decide what to do with the vr6 bbs she came on :)
Offline shaft69
« Reply #6909 on: 18 June 2014, 22:12 »
Fitted new low comp forged pistons and H rods in new engine.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
