Golf mk4
Wazzzer
overheating 20v turbo
Topic: overheating 20v turbo (Read 2985 times)
veejay53
Just got here
23 July 2004, 11:59 »
My son has a 1.8 20v turbo which is overhating. I have changed the t/stat but it still gets hot. The fans are cutting in.
I have been told it is probably the head gasket which is going to cost loads at a VW dealer.
Does anyone know of a good VW man near Egham Surrey who I could take it to for assessment and repair.
Rally_Chris
GTI forum regular
Re:overheating 20v turbo
23 July 2004, 13:46 »
I'd suspect that the impellor has broken up on the water pump - this is a common problem on the 1.8T engine at around 70-80 K. This means the water is not being circulated around the engine and through the radiator. The water pump is driven off the cambelt so this will have to be dismantled to gain access to it - get your camblet replaced at the same time.
Chris
http://www.golfmk4.co.uk
Mk4 Cruise Control Installation Expert
topher
Administrator
Serious forum addict
fully functioning
23 July 2004, 14:08 »
Agreed, most places should suggest replacing the waterpump to you when it goes in for a cambelt change. Since it's exposed anyway they usually don't charge any labour, just the ?20-ish for the part.
Chris.
golfvr6
Guest
23 July 2004, 23:55 »
Is the 1.8T an external water pump engine? i mean is not on the cambelt?
I would do what the guys suggest, as if the car does overheat then the headgasket is likely to fail.
veejay53
Just got here
24 July 2004, 07:08 »
Thanks for the sugestions, the car is being looked at today. I'll feed back the outcome, hopefully you guys will be right.
veejay53
Just got here
08 August 2004, 08:57 »
It was the water pump, changed the cambelt and had a service at the same time so all is well again.
Thanks for the suggestions.
Golf mk4
Wazzzer
