Author Topic: Really sorry but a quick VAGCOM Question!  (Read 5564 times)
Offline chrish22
Re: Really sorry but a quick VAGCOM Question!
« Reply #30 on: 15 April 2009, 21:22 »
you have tried a reboot haven't you?????
and i assume nothing else is using com 2?
Offline Dan n Nic
« Reply #31 on: 15 April 2009, 21:24 »
Just re-booted, still nothing also i have re-installed and Com 2 wasn't being used by anything else.
God dammit, it is going to be something "REALLY" simple that I haven't done I just know it!
Offline chrish22
« Reply #32 on: 15 April 2009, 21:29 »
apologies for suggesting all the obvious stuff - but you have turned the cars ignition on two clicks / or have the engine running.
I think the green light comes on - on mine before the ignition is on - which is msleading!
Offline Dan n Nic
« Reply #33 on: 15 April 2009, 22:01 »
I have tried it with the ignition turned 2 clicks, but not with the engine running so will give that a go... Cheers.
Offline Dubbz
« Reply #34 on: 15 April 2009, 22:04 »
you must be on vista?
run as admin.
2002 TDI se 100bhp-ish Auto/tip Black Magic. :cool:
Offline mikemk4gti
« Reply #35 on: 15 April 2009, 22:27 »
So, I have joined the club and also bought one of these, but I am also having problems getting it to work. The disc that it came with was unreadableso I Downloaded the software and have changed the com port, but when i click the test button  I get... Port Status: OK Interface: NOT FOUND??? (& yes it is plugged in LOL)
Any ideas?
have you downloaded the correct version of the software!
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline mart08uk
« Reply #36 on: 15 April 2009, 22:37 »
if i brought the aforementioned VAGCOM from the ebay link above would i easily be able to turn off the airbag light? sorry for asking in here, just seems appropriate  :grin: thanks
Offline Dan n Nic
« Reply #37 on: 16 April 2009, 12:59 »
run as admin.
Vista :sick: :sick: :sick: Nope, running XP, uninstalled and re-installed again this morning and hey presto, think it is working now, but haven't had time to play as I'm at work.
in general do you just use the Auto-Scan functionor select individual items???
Don't quote me on this, but i don't think so as I think this just reads fault codes, I'm sure someone else will be along at some point to tell you what it is that you do need for this!
Offline chrish22
« Reply #38 on: 17 April 2009, 13:45 »
Off the top of my head....
I used one of the auto scans to tell me what modules my car had installed.
The auto scan fault finder only works on the registered version, so I manually goto each module and scan that.
Can't say I've done anything with the airbag module - there is a tick box to not scan it - which I chose as certain cars can mess up even wth doing a read only scan on air bags.
Assuming you load the airbag module I would guess clearing the codes would remove the light.  But the light would soon come back on again unless the problem was fixed.
