Author Topic: Really sorry but a quick VAGCOM Question!  (Read 5563 times)
Offline m19ads
Re: Really sorry but a quick VAGCOM Question!
« Reply #20 on: 06 April 2009, 07:27 »
Well seem to be able to use all of the functions mentioned above all sorted, just wanted to say thanks again!  I even had a fault code come up, just need to work out where to begin with repairing it lol!! I have posted in the Garage section but its the ineterior monitoring system 01135, open circuit 36-00 so if anyone happens to have any ideas then they would be greatfully received!  :smiley:
On Order Golf GTI 5 door Tornado Red Performance Pack 19inch Santiagos Build week 11/4 currently in transit..........
2014 VW Touran SE
2004 BMW 325CI Convertible
2005 Golf GTI 5 door Black (favourite car to date)
2006 VW Touran Sport
2002 Golf GT TDI 130
Loads of non VW stuff that I don't want to confess too!!!
Offline Steve_PD
« Reply #21 on: 06 April 2009, 18:12 »
Ross Tech Wiki
 01135 - Interior Monitoring Sensors
01135 - Interior Monitoring Sensors: Open Circuit
Possible Causes
* Wiring/Connector from/to Interior Monitoring Sensors faulty
* Interior Monitoring Sensors not installed
Possible Solutions
* Check/Repair Wiring/Connector from/to Interior Monitoring Sensors
    o See Measuring Blocks
* Check Interior Monitoring Sensors Installation
 :smiley:
Offline m19ads
« Reply #22 on: 06 April 2009, 21:09 »
thanks for that, Rhyso has just replied on the thread in the garage section and suggested I look at the rear interior light unit and check the contacts in there so will take a look at the weekend!  :smiley:
2014 VW Touran SE
Offline Dan n Nic
« Reply #23 on: 15 April 2009, 20:41 »
So, I have joined the club and also bought one of these, but I am also having problems getting it to work. The disc that it came with was unreadableso I Downloaded the software and have changed the com port, but when i click the test button  I get... Port Status: OK Interface: NOT FOUND??? (& yes it is plugged in LOL)
Any ideas?
Offline Steve_PD
« Reply #24 on: 15 April 2009, 20:48 »
Does you laptop recognized the lead?? Is the driver installed??
If it is maybe a iffy lead  :undecided:
Offline Dan n Nic
« Reply #25 on: 15 April 2009, 20:52 »
Yeah, the "found new hardware" bubble popped up and I installed the drivers as per the instructions on the Ross-Tech website and the "LEDs" completed succesfully???
I may just uninstall and reinstall?
Offline Steve_PD
« Reply #26 on: 15 April 2009, 20:53 »
Have you tired all the ports and the usb port??
It going to be simple if its all installed
Offline Dan n Nic
« Reply #27 on: 15 April 2009, 20:59 »
Yep, tried different usb ports and com port. Same message. :shocked:
Offline chrish22
« Reply #28 on: 15 April 2009, 21:06 »
got mine working fairly quickly, if i recall you gave to go to the properties in device manager and change the emulated com port to a lower number.
mine installed as com port 11 initially, i changed it to com port 2 and sorted!
hth.
Offline Dan n Nic
« Reply #29 on: 15 April 2009, 21:10 »
Yeah, mine installed on com port 13 so changed that to 2 and the message says Com Port: OK , but the Interface: Not found??? but the computer recognises that it has been plugged into the USB as I get the usual "ding ding" when a usb device is plugged in?
