Author Topic: Question for manual GTi owners  (Read 1786 times)
Offline rskardon
« on: 31 March 2009, 08:55 »
Hi there,
A bit of an odd question this, with my GTi I have noticed recently that if i slightly depress the clutch when i am driving along whilst keeping my foot on the accelerator (for example on motorway) i can feel quite a lot of feedback through the pedal and it feels kind of lumpy.
Now i appreciate its not normal to be accelerating whilst puttting pressure on the clutch but i was hoping that a copule of other people might be able to try this to see if its normal? I am pushing it down, not to the point of disengaging and only for a second or two.
Its quite possible its absolutely normal because i guess the drivetrain would inhenrently carry some vibration but i wanted to guage if the lumpyness is normal.
My car is in for a big service on Monday, do you think the clutch/flywheel is something the mechanics can assess without needing to take the thing apart? My concern is with only a month left of Warrantly if the flywheel is on its way out i'll be boned if it blows,
Let em know your thoughts,
R
Offline ifti
Re: Question for manual GTi owners
« Reply #1 on: 31 March 2009, 09:59 »
I think you should get it checked - not that I have a manual. But if I was in my last month of warranty I personally would want it checked just in case. It cant hurt, and may save you a good few £'s in the long run!
Offline pitman4u
« Reply #2 on: 31 March 2009, 10:31 »
ive got a manual and i have noticed i get a bit of vibration through the clutch whilst accelerating.not really 'lumpy'. as ifti said i would get it into vw if you only got a month left on warrenty. i got a year left so ill ask them to take a look at next service. post back how you get on mate.
Offline rskardon
« Reply #3 on: 31 March 2009, 10:53 »
Thanks for your repsonses, Do you think its actually something that they can look at without having to take the thing apart? I wonder if they might tell me it cant be inspected without a good few hours work which will obviously cost a bit, its one of those annoying things that you know might be an issue but which I would guess they will just say it's fine! and then 2 months later knowing my luck it will blow.
Offline AlanD
  • MK5 2.0T 16v
« Reply #4 on: 31 March 2009, 13:40 »
I get that aswell, I know what you mean and unless you have felt it its incredibly hard to describe. Mine has felt like that since I bought it. Often when Im sitting in heavy traffic that is crawling along I will move the car without pressing the go pedal and just use the tickover and the clutch to slowly crawl and I can feel this "lumpy" feeling aswell, does yours do the same? To be honest I've never thought anything of it.
Offline ifti
« Reply #5 on: 31 March 2009, 13:58 »
If a few of you are feeling it, its most probably normal?
Offline rskardon
« Reply #6 on: 31 March 2009, 14:24 »
That sounds about right, I most recently noticed it on the motorway as i couldnt pin down a slight vibration (I had the wheels all rebalanced and full alignment done so it isnt that) so i put the clutch down just enough that it was fairly noticeable,
its quite re-assuring to hear that you get it too, i guess if i get another golf for my courtesy car that will give me a good feel as to if it is normal, nice to check on a car i'm a bit less worried about  :wink:
Offline AlanD
  • MK5 2.0T 16v
« Reply #7 on: 31 March 2009, 14:37 »
lol you should be so lucky. I got a 1.2 Polo from VW as my courtesy car :rolleyes:
Offline TomB
« Reply #8 on: 31 March 2009, 23:45 »
The rubber buffers in your flywheel have worn away, this causes the vibration.
The Caddy's at work have all been doing it for over a year, as long as the clutch doesn't slip you can normally get away with it.
Tom
MK5 Golf GTI in Tornado Red
Offline ub7rm
« Reply #9 on: 01 April 2009, 17:29 »
Can't say I've noticed this (early 05 with 37k miles ish) but I'll pay more attention  :undecided:
2020 BMW 128ti
2017 Golf GTD Estate
