Author Topic: Uregent advice needed  (Read 1941 times)
Offline matt2602
« on: 30 March 2009, 19:34 »
hi guys, ive just went to go out in my car got 200yds down the roads and the engine has suddenly started to sound like a tractor, theres a really big continuos tapping. Have the valves gone or something? checked the oil and theres oil in it. its a k reg 8v, AE engine
Offline harlemex
Re: Uregent advice needed
« Reply #1 on: 31 March 2009, 14:03 »
sounds like big end shells to me. You need to stop driving it(if this is the case that is..) or the engine will blow completely. Shells can be replaced, biggish job tho.
Offline matt2602
« Reply #2 on: 31 March 2009, 18:21 »
ive stopeed driving it stopped straight away then slowly took it back to work. the noise gets louder the more revs there are, does that still sound like the shells
Offline harlemex
« Reply #3 on: 31 March 2009, 18:33 »
I couldnt be sure without a listen whether it is shells for definate, but yes it would get louder if you rev it. Were there no other signs before this happened? Oil leaks , overheating etc?
Offline matt2602
« Reply #4 on: 31 March 2009, 19:08 »
no none got to work and it was fine then went to nip out at lunch at work got just down the road and then heard it so pulled over
Offline matt2602
« Reply #5 on: 31 March 2009, 19:10 »
what about the pistons would that make the same kind of noise?
Offline Adam
« Reply #6 on: 31 March 2009, 19:11 »
Where is the tapping coming from, top or bottom of the engine?
Down Hill From Here.
Offline matt2602
« Reply #7 on: 31 March 2009, 19:18 »
from the top by the sounds of it when its getting louder, when the car is idling it shakes like anything too
Offline Adam
« Reply #8 on: 31 March 2009, 19:21 »
Maby shaking indicated it is miss-firing?? Whip the spark plugs out, are any of them wet?
Offline matt2602
« Reply #9 on: 31 March 2009, 19:23 »
shouldnt be as its been dry for the last few days, if it was misfiring would it also make that noise?
