Golf mk3
hardmonkeys
Uregent advice needed
Topic: Uregent advice needed (Read 1937 times)
Adam
Forum addict
Re: Uregent advice needed
Reply #10 on:
31 March 2009, 19:46 »
No but shaking would say so.
Maby your timing belt has slipped?
Down Hill From Here.
matt2602
GTI forum regular
Reply #11 on:
31 March 2009, 19:58 »
ill pull the plugs out and give them a clean and see what happens. when you rev the car it sounds as if something is vibrating its 3 quite loud noises as soon as you rev it plus its began to have a pretty strong smell of fumes from the exhaust aswell now
Adam
Forum addict
Reply #12 on:
31 March 2009, 20:09 »
Unburnt fuel is entering the exhaust, definitely missing. Broken cam shaft me thinks.........
matt2602
GTI forum regular
Reply #13 on:
31 March 2009, 20:15 »
and if its that thats going to cost a bit isnt it?
Adam
Forum addict
Reply #14 on:
31 March 2009, 20:31 »
IF
it is then depends if you want to buy new, check scrappies. It is only an idea, only way to deff tell is to remove the rocker cover.
matt2602
GTI forum regular
Reply #15 on:
31 March 2009, 20:34 »
i take it you'll be able to see straight away if i take the rocker cover off? sorry not done much mechanics on cars but not shy in giving it a go
Adam
Forum addict
Reply #16 on:
31 March 2009, 20:41 »
yea you would be able to see it if you looked closely at the cam.
RFC84
GTI forum regular
Reply #17 on:
31 March 2009, 20:48 »
i'll give that a look 2moro when it's light
matt2602
GTI forum regular
Reply #18 on:
01 April 2009, 18:59 »
just took the roker cover off and had a look at the cam shaft it all looks ok
Golf mk3
hardmonkeys
