Author Topic: WANTED - STANDARD FITTING KITS FOR THE RECIRCULATING D/V  (Read 4061 times)
Offline sax4u
I have bought my Golf Gti turbo with a atmospheric Bailey d/v already on it, and i read somewhere in this forum that its not doing it any good, and that i should stick to the re-circulating one..is this true, but i noticed i will need another pipe to put a standard valve back on, so was wondering if anyone may have one laying about that would like to sell it to me. At the moment, this d/v is seems to be running alright so im not sure whether to put an re-circulating one back on, or just leave it? I have an AGU engine, and no lights or anything is showing. I have took it to a VW garage to get the ecu checked out, and its showing no faults at all! Any help or suggestions is grately appreciated. thanx
Offline navmk4gti
Re: WANTED - STANDARD FITTING KITS FOR THE RECIRCULATING D/V
« Reply #1 on: 30 March 2009, 01:20 »
it is recomended BUT on agu engines ( i have the same) it is said an atmospheric is fine and will not give you any mechanical problems.. but are you getting any turbo lag through the rev range?? if so then its best to get a forge 007 or a forge splitter-r which is what i have in my golf .. and it does the job ace.. also gives nice whoosh sound  :smiley:
Offline sax4u
« Reply #2 on: 30 March 2009, 09:52 »
Quote
Hi..thanx for your reply, yes i do get alil turbo lag when you put your foot down, but its only for a second or two, im not sure whether that d/v has anything to do with it, cos i heard that its a common thing on the Golfs!..is that true? If that d/v is def causing that turbo lag, then yes i would like to change it back to a re-circulating one, but im not sure how to put it back, cos i think i need an extra pipe to put it back, but not sure where to get hold of one.
« Last Edit: 30 March 2009, 19:11 by richw911 »
Offline navmk4gti
« Reply #3 on: 30 March 2009, 14:13 »
can you post up some pics mate of you'r dump valve layout so far ..  :nerd:
Offline barry-gti
« Reply #4 on: 30 March 2009, 14:17 »
i've got a standard bosch DV if u want that. assuming the one from an AUM fits urs?
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #5 on: 30 March 2009, 14:36 »
the forge splitter dv will be fine with an agu engine as on the agu it doesn't have to re-circulate like on an aum engine and won't cause issues with the ecu etc the forge dv is preferable to the bailey unit
2000 Mkiv GTi 1.8T AGU
Offline sax4u
« Reply #6 on: 01 April 2009, 00:10 »
Hi..mines the agu, but would yours fit on mine? thnx
quote author=barry-gti link=topic=111268.msg969012#msg969012 date=1238419072]
[/quote]
Offline sax4u
« Reply #7 on: 01 April 2009, 00:13 »
Thanx for the advice, i feel ahell lot better now! but its just a normal Baileys thats on it now, so would that be alright?
Offline sax4u
« Reply #8 on: 01 April 2009, 00:16 »
Hi..im not so clever when it comes to posting pics im afraid, dont know how to do it, but all i know, its on the back of the engine on the driver side. Hope this helps?
Offline sax4u
« Reply #9 on: 01 April 2009, 00:17 »
Yes i would luv to take that off you, how mush do you want for it? thanx
