Author Topic: fitted amp  (Read 2045 times)
Retro_look
fitted amp
« on: 29 March 2009, 16:56 »
i fitted a amp and some 6x9s in my mk3 gti
all works ok but when i have a cd on and the volume is set very low i can hear the radio though the 6x9's even though the head units set to cd, any ideas??
sharpie
Re: fitted amp
« Reply #1 on: 29 March 2009, 17:06 »
sh!t wiring, crap cables, no insulation.
Retro_look
Re: fitted amp
« Reply #2 on: 29 March 2009, 18:50 »
think the wiring kit is a fusion kit, are they crap? if i buy a rca lead noise surpressor would this help?
thanks
Retro_look
Re: fitted amp
« Reply #3 on: 29 March 2009, 21:22 »
my bro had a rca supressor so put it on but its made no difference, which cable would need insulating more ??
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re: fitted amp
« Reply #4 on: 29 March 2009, 23:51 »
Check you haven't got cables coiled up - when you coil a cable it works, essentially, as an aerial.
Neaten up your install if at all possible, people rarely consider how neatness can actually affect SQ
The greatest leveller of them all - the Carousel
Retro_look
Re: fitted amp
« Reply #5 on: 31 March 2009, 20:09 »
was having a play around today and i moved the rca leads from the rear outlet to the front outlet and now the speakers work as normal with no radio noise.....the front outlet is right next to the aerial output and the rear is futher away
Retro_look
Re: fitted amp
« Reply #6 on: 19 April 2009, 16:53 »
replace my head unit and problem is sorted, nothing to do with my wiring or the quality of the cables  :smiley:
