Author Topic: advice on coilovers  (Read 2784 times)
Offline jazzgti777
advice on coilovers
« on: 27 March 2009, 14:54 »
hay ppl.
i wanting to lower my golf but not shure what coilovers t buy?
ive got a budget of about £250
has anybody knw what colies i should buy?
my car has got 18" rs4s on. so what would be a good level to lower it to?
45"? 60"? any ideas. :undecided:
its a golf gti mk4 1.8t 1998 will this effect anything with it being 1 ov the 1st 1ns?
thanks nathan
« Last Edit: 07 April 2009, 08:52 by jazzgti777 »
Offline topher
  • Administrator
  • fully functioning
Re: advice on coilovers
« Reply #1 on: 27 March 2009, 15:05 »
£250 will get you a budget coilover kit (assuming you want new and not 2nd hand). All the budget kits are pretty much the same so you might as well just get the hottuning ones from here http://www.golfgtiforum.co.uk/index.php?topic=103405.0
40mm is about the right drop. Low enough to look good, not low enough to cause any problems. You can achieve that kind of drop though with a decent spring and shock setup.. and you'll get something much better quality for your £250 than a set of cheap coilovers.
Offline andc1
« Reply #2 on: 27 March 2009, 15:28 »
i had coilovers on mine but took em off and got springs instead, much smoother!
Offline jazzgti777
« Reply #3 on: 27 March 2009, 17:06 »
ok cheers and were could i get a decent set of springs and shocks?
Offline 1.6mk4GOLF16v
« Reply #4 on: 27 March 2009, 17:20 »
is it true that youll get more tyre rub on the arches with a shock/spring kit?
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline andc1
« Reply #5 on: 27 March 2009, 17:20 »
standard shocks and the springs are from here!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=400035195137
just tell em what model yours is and they'll send em out in about aweek, worth changing the top mounts and bearings aswell, gfs is best for those, £20 ish quid for the lot
Offline andc1
« Reply #6 on: 27 March 2009, 17:22 »
225 40 18's on mine and no rub on springs with a  40mm drop
« Reply #7 on: 27 March 2009, 17:30 »
so basically i just need these springs to lower the car to 40mm?? how come theyre so cheap?
whats the difference between these n coilovers?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline Steve_PD
« Reply #8 on: 27 March 2009, 17:56 »
Coilovers are adjustable  :wink: you can have a 5mm drop or a 75mm drop  :cool:
Offline Voodoo-Music
« Reply #9 on: 27 March 2009, 18:00 »
I have had a few sets of coillies and i dont like em now, its not as easy as it sounds to wind them up and down. You have to clearcote them everytime you adjust the suspension and needs lots of servicing.
I have a 50mm drop on 19s and it does not catch
Shock and springs are the way, easy, low maintenance and smooooooth
