Author Topic: my speakers are buzzing / poss remote fault  (Read 2579 times)
Offline mk3 tdi
« on: 26 March 2009, 19:29 »
just a simple query from an amateur
i have put an amp and speakers but the remote lead from my deck wouldnt work, so i played with it till i found the only remote for the amp i could - which was a wire coming from the ignition to the deck, now when i put my headlights on the speakers make a "thud" type noise and also buzz while driving.
please help
i will give half a packed of cheese and onion crisps and the cookie my kid left over from his school lunch.
Offline Dan J
Re: my speakers are buzzing / poss remote fault
« Reply #1 on: 26 March 2009, 21:13 »
you need to find the remote output on your headunit really, if you keep it as it is you could i asume damage either the ignition,headlight relay/loom or your speakers/sub etc.
what headunit you got dude
Offline mk3 tdi
« Reply #2 on: 26 March 2009, 21:54 »
oh its there - its got a proper remote wire but it doesnt send a signal - ive used a tester on it and no signal coming out of the deck - is there anything else i can use?
Offline mk3 tdi
« Reply #3 on: 26 March 2009, 21:56 »
eerrrm - you know one of my headlights has stopped workin.......    bulbs fine - no power going to the positive on the plug that connects to the headlight.........
Offline LazyLunatic
  • MK3 20VT Project
« Reply #4 on: 26 March 2009, 22:14 »
new headunit :undecided:
sounds like a bodge which hasnt worked well and you found out the hard way.
i had a problem at one point where 6x9s sort of buzzed/whined with the revs, so as i revved the engine, the noise got louder and higher. you can see what i mean. went away though.
LL ;)
Offline Adam
« Reply #5 on: 27 March 2009, 00:41 »
Find a live and put a switch on it..... remember to switch it off though. Other tan that did a mates Clio and used the same as you, same reason as well......wasn't a JVC was it?
Down Hill From Here.
Offline mk3 tdi
« Reply #6 on: 27 March 2009, 00:46 »
no - its an old alpine
Offline Len
« Reply #7 on: 27 March 2009, 08:14 »
LL ;)
That kind of buzz with revs is down to a bad earth.
www.sas.org.uk
www.the-ace.org.uk
Offline mk3 tdi
« Reply #8 on: 27 March 2009, 20:45 »
mine doesnt do it with the revs - its just a contant littel buzz when the lights are on
Offline mk3 tdi
« Reply #9 on: 05 April 2009, 20:33 »
now sorted - have got the remote from cig lighter with a switch on it
