Car audio
Removing head unit
Topic: Removing head unit (Read 3023 times)
Onge
GTI forum regular
Removing head unit
20 July 2004, 13:34 »
Can anyone assist?
I have a sony head unit - radio and tape in my Golf, which i need to remove, so i can fit a new unit.
Problem is, i dont have the removal rods that you need to extract the unit. Can it be done?
Colin
Re:Removing head unit
20 July 2004, 13:58 »
use a chainsaw or if possible "a hand grenade"
Colin
20 July 2004, 14:16 »
oh ok then.......Halfords sell the removal tool your after.
about a ?5 which is cheaper than a new dashboard.
jte
Of course! Get two tiny screw drivers/big paper clips/stiff wire/anything less than 2mm in diameter made of non bendy metal, stick them down the sides of the head unit and push the retaining clips out. The whole thing will slide out with a bit of a tug. You can do one side at a time.
I took the sony HU out of my MK3 recently using this method. Takes a bit of trial and error to fing exactly where the clips are but works. I pulling the bits of dash trim out from either side gives a bit more space. Both just pop out quite easily.
A VR6 isn't a way of life, it's just a car.
Dizzie
Forum addict
Make friends with your fast
20 July 2004, 14:22 »
the mk3 headunit can be removed (and stolen) without keys. Just remove the 4 screws and pull the whole lot out with the headunit still in it's cage still attached to the plastic with the air ducts on. the design is so lame
Mk4 Golf 150PD
Onge
GTI forum regular
20 July 2004, 16:22 »
Cheers All,
I'll have a go this week..........get that Clarion ordered !!
Car audio
Removing head unit
