Author Topic: amp fitting under the seats?!  (Read 3603 times)
Offline jay cee
  • always in front
« on: 20 March 2009, 15:37 »
hi all
why are the damned seats in the GTI so low! normally I wouldnt mind, but I want to put an amp under, and it's just not roomy enough, maybe near the passenger footwell area I will try. But I know that someone will kick it when sitting there.
grrrrr!
1997 Golf GTI 8v - Dragon Green
http://www.nwdubs.com
www.rouleur.cc
Offline euro dave
Re: amp fitting under the seats?!
« Reply #1 on: 20 March 2009, 15:50 »
have you looked at Genesis amps?  They're very low profile.....
Offline JC
  • Back in the North.
« Reply #2 on: 20 March 2009, 15:58 »
i wouldnt fancy fitting an amp under the seat due to the HEAT  :huh:
Offline Shady Pioneer
  • graphic designer.
« Reply #3 on: 20 March 2009, 15:59 »
Plus it's managing the wires as well, making sure they are out of sight. You're better off putting it in the boot.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #4 on: 20 March 2009, 19:06 »
I wouldnt put them under the seats,  seems a very very common fault on the golfs is the rear like seals leaking and all the rain water runs under the rear seats.  Could make for great heated seats though,  put them under the front seats  :laugh:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline euro dave
« Reply #5 on: 20 March 2009, 22:07 »
Is there enough space to mount an amp under the glove box?  I know there's enough room in a Polo.....
Offline jay cee
  • always in front
« Reply #6 on: 21 March 2009, 20:53 »
i originally tried to fit it under either of the front two seats, but the amp is to deep.
www.rouleur.cc
Offline JC
« Reply #7 on: 21 March 2009, 20:57 »
boot it is then  :wink:
Offline drapergti
« Reply #8 on: 27 March 2009, 21:33 »
I tried also, passenger side was fine on my mk2, however the drivers has too many obstructions. I have a board covered in fabric fixed to the back of the rear seats. The board slides under the metal tubes running vertically and the amps screw to the board.
Offline jay cee
  • always in front
« Reply #9 on: 27 March 2009, 23:45 »
any pics of this please mate?
www.rouleur.cc
