Author Topic: Changing Brakes  (Read 2278 times)
Offline Max GTI
Changing Brakes
« on: 20 March 2009, 12:00 »
Hello Guys
As the title says im looking to change my brakes, I know a lot of people seem to go for the R32 or Cupra brakes but I want to keep mine the same size, just changing them for better discs and pads as the car is remapped already and still stops fine and isn't likely to get much quicker with the other mods I need/plan to do. (milltek, dv dsg intake and tip)
Iv looked of the net this week and haven't had much luck, il looked on Brembo and places like that but when I find some they looked like a big upgrade as the kit was over £1000.
I think my brakes are the following size (not 100% if wrong please correct my lake of knowledge  :smiley:)
Front- 312mm
Rear 256mm
Also when I change my discs I want to get vented ones because they look  :cool: :cool:
Thanks for all your help in advance.  :smiley:
Max
25th Anniversary
No. 1117
Offline Rhyso
Re: Changing Brakes
« Reply #1 on: 20 March 2009, 12:02 »
you've already got vented brakes mate  :wink:
i bought these and had them fitted yesterday
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=230324593648
first impressions are good and will be more than adequate for every day road use  :smiley:
Offline Max GTI
Re: Changing Brakes
« Reply #2 on: 20 March 2009, 13:42 »
Sorry not vented discs drilled discs.  :rolleyes:
like these
http://images.minispeed.co.uk/140-8740.jpg
25th Anniversary
No. 1117
Offline Rhyso
Re: Changing Brakes
« Reply #3 on: 20 March 2009, 13:44 »
like these
 :tongue:
read this and make your mind up
http://uk-mkivs.net/forums/t/153276.aspx
IMO drilled discs are not necessary for every day road use  :nerd:
Offline dobber
Re: Changing Brakes
« Reply #4 on: 20 March 2009, 14:02 »
Arent teh standard disks 288mm, therefore you would need different carriers?
I shall cleave you in twain with the Mighty Sword of Dobber. (Harry Enfield and Chums)
Offline Rhyso
Re: Changing Brakes
« Reply #5 on: 20 March 2009, 14:28 »
that is correct but i upgraded to the 312mm's about 2 years ago :smiley:
Max's Anniversary comes with the 312mm's as standard
Offline Max GTI
Re: Changing Brakes
« Reply #6 on: 20 March 2009, 15:33 »
Thanks Rhyso
A BIG help and very interesting, looks like il be getting some decent brake pads and have some more money in the back pocket for other mods.
Thanks again.  :smiley:  :smiley:
25th Anniversary
No. 1117
Offline gjroe78
Re: Changing Brakes
« Reply #7 on: 20 March 2009, 15:35 »
like these
 :tongue:
Why does whoever wrote that thing about brakes say this :
Drilled discs
A common misconception is that the purpose of drilled discs is to promote cooling. This couldn't be further from the truth, The real purpose is to reduce weight.  :shocked:
Drilling can allow brake dust and gases to escape, but with modern brake pads, this usually isn't a problem. Choosing a drilled disc for that purpose doesn't make a whole lot of sense.
Many high performance cars like Porsche and Mercedes AMG come with drilled discs from the factory. For these cars, the drilling is mainly about the looks, just like bright red calipers. When people do serious high-performance driving on a trackdays, they usually swap to regular plain discs.
Drilled discs generally wear out brake pads faster and produce much more brake dust as a result.
Drilled discs have a shorter service-life than plain discs and tend to develop stress fissures/cracks over their lifetime
 :grin: :laugh: :grin:
Offline Max GTI
Re: Changing Brakes
« Reply #8 on: 20 March 2009, 16:54 »
What pads would you guys recommend then, a set of EBC and I guess either greenstuff or redstuff ones.
25th Anniversary
No. 1117
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Changing Brakes
« Reply #9 on: 20 March 2009, 21:50 »
I would buy the EBC plain discs rather than the more expensive turbogroove's, & either the red or yellow stuff pads, depending on how hardcore your driving is. ;)
They're quite cheap from www.buypartsby.co.uk
ps  You will need to look at the Audi app's if you want the yellowstuff. :afro:
There's a pattern to the p/no.'s. ;)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
