Author Topic: another spongy brake issue. its getting boring now!  (Read 1173 times)
Offline paultownsend
so while changing my ball joints, i slipped and dropped the caliper causingit to leak.
no worry, they were all bubbling anyway, and i had a set of goodridges.
the osf solid line needed replacing , no worries as i had all the bits and tools. the other 3 pipes to the calipers i just put new unions and flares.
i didnt however bother touching the under beam hoses. they seem in good condition with no blistering.
so came the bleeding. handbrake cables off, bias valve clamed open. a litre of dot 4 through each corner in the correct order with the eezibleed, then repeated with the 2 man method. all seemed to be going well.
with the engine off, a good firm pedal. as soon as the engines on, long spongey pedal. handbrake on, engine on, soft pedal, pump a few times, good pedal.  whats going on! im the brake bleeding master!  :grin:
« Last Edit: 20 March 2009, 19:17 by paultownsend »
Re: another spongy barake issue. its getting boring now!
« Reply #1 on: 19 March 2009, 09:30 »
You have a master cylinder issue, might be on its way out or you have air trapped, could also be the servo unit failing.
« Reply #2 on: 19 March 2009, 17:09 »
the m/c is a 22.2 item new 18 months ago, to go with my g60 280 fronts.
i had a firm pedal before the hose went
Offline Dolly
« Reply #3 on: 19 March 2009, 20:51 »
i fitted all new brakes on mine and new lines, clamped the bias valve and pressure bled twice. probably about 2L of fluid! was pure stuff coming out. i have a really dangerous pedal.
although i did notice the pedal felt firm with the clamp still on the bias valve? ive got a 22mc to fit so ill try again. sorry to jack the thread but if anyone knows a tried and tested bled method im all ears.
Offline sidecarphil
« Reply #4 on: 19 March 2009, 21:20 »
did you pump the pedle before operating the hand brake ???
« Reply #5 on: 20 March 2009, 09:19 »
Rereading this, if your having to pump the pedal to get a firm pedal then you have air somewhere in the system.
« Reply #6 on: 20 March 2009, 18:47 »
handbrake cables were the last thing to go on. so i pumped yes, to bleed the brakes. rear pads were set to 1mm gap as per bently/haynes
