Author Topic: 2x15's jl audio box  (Read 2970 times)
Offline bully85
2x15's jl audio box
« on: 17 March 2009, 14:17 »
could sumbody post me the best dimensions for a box to take 2 jl audio 15w6's for a mk4 boot have the hole boot to play with thanks
Offline upfront84
Re: 2x15's jl audio box
« Reply #1 on: 17 March 2009, 16:28 »
W6  :grin:  good choice, great sounding sub, you looking to go ported or sealed?  space may be a bit tight for 2 15s ported, what are your boot dimensions?
Offline bully85
« Reply #2 on: 17 March 2009, 20:13 »
 was thinking of sealed as the space issue wich is better anyway?have been on jl audio website and have got the reccomended dinmensions and i can fit 4 in 2 boxs back 2 back with no space left would this be wroth it as  i already have the 4 subs so as i could fit them all in to the reccomended dimensions?thanks
« Last Edit: 17 March 2009, 20:20 by bully85 »
Offline upfront84
« Reply #3 on: 18 March 2009, 09:26 »
Have you already got the amps for the subs?  How much power are you running through each sub? (RMS)
Offline bully85
« Reply #4 on: 24 March 2009, 13:31 »
got a hifonics amp is it worth runing four?
Offline upfront84
« Reply #5 on: 24 March 2009, 16:23 »
Hi Bully, sorry for asking lots of questions but cant help unless i know what you have and what your looking for.
The w6's can work in a 'relatively' small enclosure so you might be able to squeeze them all in, to be honest i probably wouldnt bother unless you are losing the rear seats or felt like going down the wall route?  and can afford another amp.
Thought about selling the other 2 subs to fund some of the install?
What model number amp have you got?
You'll need about 5.5cuft to run two subs ported half that to run them sealed which may allow you to fit 4 in.
Personnally i;d rather run 2 subs in bigger ported boxes than squeeze 4 in with less power/space each.
If you can confirm the following I'll knock up a couple of box designs this week.
Amp model number
voice coil configurations (i.e. ahve you got a dual 4 ohm voicecoils on your subs?)
boot space
If you just want the recommended box sizes:
http://mobile.jlaudio.com/pdfs/15_18W6_BDS.pdf
Offline bully85
« Reply #6 on: 24 March 2009, 22:13 »
hi thats the link i found and the boxs are bein made up now and thay just fit in so do you think 2 amps?
Offline upfront84
« Reply #7 on: 24 March 2009, 23:07 »
yeah 2 amps would be good  :grin: no harm in having a bit of headroom
post some pics when its all in  :cool:
Offline bully85
« Reply #8 on: 25 March 2009, 12:02 »
pm me ur num and i wiil send you pics of the boxs
