Author Topic: Need some suspension/ride height help ASAP...  (Read 1902 times)
Offline twistedblack69
  • Proud mk2 user and abuser
« on: 16 March 2009, 14:19 »
Ok so I've seen the thread in Mk2 Maintenance about measuring ride height. It says "to measure you're cars drop, measure the distance from the centre of your wheels to the bottom of the metal arch". Thing is...I don't understand what he meant by the bottom of the metal arch?? At the mo, my car's so low I can only get my fingers in there up to my first joint in my middle finger (closest to knuckle) and I can't feel anything on the rear, but on the front I can feel something that's seperate to the outside of the plastic arch, but still feels like plastic, I can't find any metal  :undecided: :undecided: I suck at this
Offline Ben Lessani
Re: Need some suspension/ride height help ASAP...
« Reply #1 on: 16 March 2009, 23:35 »
You can probably feel the inner arch liner, the plastic arch won't sit that much lower than the metal one - mine is about 1cm off.
Doesn't help much, but you'll just need to feel your way round.
« Reply #2 on: 17 March 2009, 10:31 »
Yea that's what I thought I could feel on the front, the arch liner, mine was measuring -60mm to the lowest part of that as in...if you're looking down the side of the car, the outermost part (where it flares)
Offline JC
  • Back in the North.
« Reply #3 on: 17 March 2009, 10:48 »
i cant get my fingers in front or rear  :shocked: oooo er missus
« Reply #4 on: 17 March 2009, 12:57 »
Helpful as always  :rolleyes:  :rolleyes:
Offline JC
« Reply #5 on: 17 March 2009, 13:01 »
 :rolleyes: the plastic arch trims are approx 3 mm thick. the only way u can measure to metal is by removing them all.
can i DARE to ask why you want to know this, do you have issues or just want to know how low it is .
Offline Organisys
  • Old and Slow...
« Reply #6 on: 17 March 2009, 13:08 »
There is an easier way.
1. Look at car.
2. Decide if it is low enough
3. Leave it, or lower it some more.
 :grin:
« Reply #7 on: 17 March 2009, 16:24 »
I have issues with rubbing and want to know how low it is. I was looking at 60mm drop springs, was told by previous owner it was 80mm at the mo, but when I measured it it measured around 60mm, so looking to get 40mm now
Organisys...how do I know how much to lower it by (or raise, as the case is) if I don't know what it already is??
Offline JC
« Reply #8 on: 17 March 2009, 17:25 »
i got told with my drop, alloys offset, tyre size etc etc I wouldnt rub,  :lipsrsealed: also got told that a mates was 80mm drop, yet i know mine is 60 but was lower than his  :laugh:
I rubbed, both front and rear,  :rolleyes:
solved the rear by swithcing rear shocks,
front is BETTER , by a combination of NEw top mounts and the tyre wearing away  :laugh:
are you on coilovers ?
Offline spankier
« Reply #9 on: 17 March 2009, 20:04 »
sorry to butt in but does anybody know the standard wheel centre to arch measurement (ie non gti) ive never owned one on standard suspension and im in a similar dilemma (plus it would be a usefull number to have on a thread like this.... ;)  )
