Author Topic: Grinding noise from steering wheel. Need some lube!  (Read 3898 times)
Offline Dec
On saturday my steering wheel started making a grinding noise when turning.
I think it just needs something greesing, but any idea what? Do I need to remove the steering wheel?
My mk2 did it too, but I just left it because i couldnt be bothered to sort it but this car is sooo much better, its a bit embarasing to be honest!
Cheers :)
« Last Edit: 12 March 2009, 11:30 by Dec »
Offline VR6-Joe
Re: Grinding noise from steering wheel. Need some lube!
« Reply #1 on: 12 March 2009, 11:33 »
It's all the metal filings on the back of the steering wheel..
Take your steering wheel off, brush away all the metal filings, stick the steering wheel back on - sorted.
Common problem I think, as my old Mk3 kept doing the same thing so I read up on it on another site, did the above and it went away.
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline VR6-Joe
Offline Dec
« Reply #3 on: 12 March 2009, 12:01 »
Cheers mate :)
Should be able to greese it up without taking it off :)
« Reply #4 on: 12 March 2009, 12:24 »
It could be the top bearing breaking up.
Offline Dec
« Reply #5 on: 12 March 2009, 12:28 »
Hmm, is that serious?
It looks grimey behind the wheel where the horn contact is. I'll give it a lube up and see what happens, try the easy things first :)
Offline leegt5
« Reply #6 on: 12 March 2009, 20:49 »
Its the horn contact on the back of the steering wheel slip-ring the grease dries up and grates... Wipe the filings if theres any and put a bit of contact grease on them.. Thats whatmine did and its been fine since...
Doubt it will be the top bearing, if it was that grinding you'd feel alot of play if the bearings were that shot !!
Offline Mikester
  • Civic Type R
« Reply #7 on: 12 March 2009, 20:56 »
i had this. i never took the wheel off, i used a cotton bud to clean it, then another cotton bud to apply the grease. went for a drive with lots of steering, and applied a few more times. job done, no more noise.
Offline Dec
« Reply #8 on: 12 March 2009, 22:40 »
Cheers mike! Sounds like a plan :)
I can see quite a bit of dirt behind there so guessing its that :undecided:
No play in the wheel either :)
Cheers guys!
Offline eightyeightmph
« Reply #9 on: 12 March 2009, 23:07 »
Yep mine was the same, cleaned & greased when I fitted my MOMO wheel! :afro:
2016 GOLF GTD
