Author Topic: rear bias braking problem?  (Read 1084 times)
Offline purplebug
« on: 11 March 2009, 15:44 »
my golf seems to be locking up at the rears when braking. even when first getting into car and reversing out drive if I brake I hear the rears coming on. any ideas? My pedal doesn't seem as good as my neighbours identical car but it passed MOT just a few weeks ago.
Offline JC
  • Back in the North.
Re: rear bias braking problem?
« Reply #1 on: 11 March 2009, 16:02 »
there is some sort of valve on the rear beam, mine was seized, wheni got the lines changed the garage freed it off, made a BIG difference to mine
search time  :wink:
Offline purplebug
« Reply #2 on: 11 March 2009, 16:08 »
when I got my brake bled they said they freed that valve thing off but maybe its still jammed, might take it back for a check. Still wondered why pedal ain't as good as my neighbours though?
Offline dubber36
« Reply #3 on: 11 March 2009, 16:28 »
The load compensating valve is probably worn out. It moves about every time you go over a bump, so after 20 odd years it'll be a bit tired.
It can also be a cause for seized rear calipers. If it is not giving enough pressure to the rear, the calipers will seize up from not being used.
I think they are around £60 to replace.
Offline purplebug
« Reply #4 on: 11 March 2009, 16:42 »
Cool, the rear calipers are brand new and giving the opposite effect of too much rear braking and nowt from front. Is this £60 from VW or another?
Offline boneybradley
  • Back in a Mk3...
« Reply #5 on: 11 March 2009, 17:11 »
Someone (I think rubjonny) has done a guide on here about adjusting the rear bias valve.... I adjusted mine as the guide said (as mine has mk2 rear brakes!!) and it was just a matter of modifying the spring (I cant find it now but it's defo a mk2 section bit)
found it http://www.golfgtiforum.co.uk/index.php?topic=27064.0
Offline purplebug
« Reply #6 on: 11 March 2009, 19:54 »
nice one, i'll give that a bash first  :smiley:
Offline Mk2George
« Reply #7 on: 11 March 2009, 21:55 »
Also, if you have recently lowered the car without adjusting this compensator then by default it will give you heavier braking at the rear
