Author Topic: What cam shaft to fit mk2 gti 8v  (Read 9405 times)
Offline jayz1981
« on: 08 March 2009, 22:01 »
hi there im going to bye a roadfast cam shaft on wednesday but not to shore wich one to go 4 as its my daily driver
was thinking about kent road fast cam kit with vernier pully or is a piper kit better help???????????????? :shocked:
Offline Ben Lessani
Re: What cam shaft to fit mk2 gti 8v
« Reply #1 on: 08 March 2009, 22:39 »
Out of interest, what kind of price is the cam coming in at?
You should throw the 2.0l bottom end on to really ramp up your torque.
Offline jayz1981
« Reply #2 on: 08 March 2009, 22:45 »
hi ben the kent cam kit is £287 comes with cam/followers/timing disc/ the power pully is £95
the piper is £415 all in
Offline Ben Lessani
« Reply #3 on: 08 March 2009, 22:51 »
Whoah, that's a whole lotta money for some relatively small gains, I always though cam's were only about £100.
Offline jayz1981
« Reply #4 on: 08 March 2009, 22:56 »
yer thats what i thought you can get cams 4 that money but been told you need cam followers wich are £125 and then the pully wich is £100
it says i will gain 15bhp
Offline Ben Lessani
« Reply #5 on: 08 March 2009, 23:02 »
You'd be better off (money, power and torque wise) by fitting the 2.0 bottom end (2E, AGG, ABA, 3a, AWG, AWF) and get about the same power increase, but oodles more torque for much less money (if you can DIY that is).
Offline jayz1981
« Reply #6 on: 08 March 2009, 23:08 »
sounds like a big job and i dont think i could take it on where as the cam should b quite easy but i will look into it thanks ben
if anyone is near west sussex and could do the bottom end 4 around £400 let me know also some more help on the cam kit would b great
Offline Ben Lessani
« Reply #7 on: 08 March 2009, 23:31 »
Well, cams are a doddle to fit. It takes about 10 minutes to get the belts off and mark up. About 5 minutes to remove the rocker cover. Then about 5 minutes to crack off the cam bearing caps.
The only trick is getting the timing right on a new cam.
Whereas a bottom end is a bit more hard work. You'd need to drain the oil and coolant, remove the belts, alternator, PAS pump, water pump, water hoses, starter motor, gearbox, then crack the head off, replace the head gasket and bolts, new oil and filter with new block and a fresh batch of coolant.
The coolant, oil filter, oil, head set would set you back about £40-50. You'd need the TSR spacer for the dizzy though, not sure on price. The blocks can be picked up cheeeeep, usually <£100. The work itself isn't hard - as long as you have the tools. The knowledge you gain from doing it is invaluable though!
I'd throw the £400 at a decent socket set, £100, a decent torque wrench, £40, a new clutch, £60  and the block and bits from the above. You'd come in under budget with more power and a decent sense of satisfaction ;)
Offline Diamond Hell
  • Opinions я Us
« Reply #8 on: 08 March 2009, 23:42 »
Bottom end before cam, all day long.
Plus you're going to see a lot more gains if you put the cam in a ported head, too.
Offline jayz1981
« Reply #9 on: 09 March 2009, 18:38 »
thanks 4 the advice but im still going to get the cam kit because i can do it myself quick and when the head gasket goes i will get the bottom end sorted but can anyone tell me wich cam is best 4 mk2 gti 8v thanks jason
