Author Topic: AGU engine in VW Passat...  (Read 2496 times)
Offline twistedblack69
  • Proud mk2 user and abuser
« on: 08 March 2009, 19:53 »
I'm having some thoughts on a certain "upgrade" for my mk2 Golf GTI (sure it won't be too hard to guess what  :grin: :grin:) am I right in thinking the 1.8t engine in the '97-'98 Passats is AGU?? Any other 1.8t AGU engines you guys know of??
Offline richw911
Re: AGU engine in VW Passat...
« Reply #1 on: 08 March 2009, 19:54 »
Yep AGU  :wink:
« Reply #2 on: 08 March 2009, 20:13 »
You can get a 150, 180, 200 or 225 engine, am I right?? What comes in the Passat, or are there different ones in different..."trim levels"?? (for want of better words)
Offline Jimp
« Reply #3 on: 08 March 2009, 20:29 »
150 and 180 are in the Passat as far as I know.
Not low enough mk5
Not on the road enough mk3
Offline richw911
« Reply #4 on: 08 March 2009, 20:31 »
Indeed and AFAIK the early ones are 150 AGU.
Some info one 1.8Ts here : http://www.golfgtiforum.co.uk/index.php?topic=89491.0
« Reply #5 on: 08 March 2009, 20:39 »
Kool man, cheers....so you can only get an AUG engine that puts out 150bhp??
Offline richw911
« Reply #6 on: 08 March 2009, 20:54 »
No ARZ is also 150. as is AUM although it has the k03s turbo.
From 98 - 2000 the engines had the k03 turbo. 150 BHP  (AGU / ARZ)
From 2000 on thay had k03s VVT  150 BHP ( AUM )
From 2002 on thay had 180 bhp (same as 2000 on with different ECU map) standard and 6 speed box. ( AUQ / AWP )
BAM is the 225 bhp 1.8T that was never fitted to the passat tho  :smiley:
« Last Edit: 08 March 2009, 20:56 by richw911 »
Offline DubFan
« Reply #7 on: 09 March 2009, 12:38 »
I don' think there was ever a 1.8T with 180bhp in the Passat because they had the 2.3 V5 with 170bhp.
« Reply #8 on: 09 March 2009, 13:04 »
Correct in the pre 2001 Passat range they did the 1.8T and the Vr5 with 150bhp plus the 2.8 V6 with 193bhp, the later 2001 on range was still 150 for the Turbo but the Vr5 was upgraded to 170BHP.
