Author Topic: they say things fail in 3s......  (Read 12471 times)
Offline richw911
Re: they say things fail in 3s......
« Reply #50 on: 13 March 2009, 23:26 »
UPDATE
big thanks to Dai-Cymru (again!)
solved my boost leak - guess i'll never learn from past mistakes - forgot to swap the o-rings off the old pipe onto the new Forge Pipe  :embarassed:
so boost leak solved BUT possibly another even larger problem spotted - oil in the intercooler  :angry: :cry:
that normally means that a seal is going somewhere and the likely candidate - TURBO  :cry: :cry:
i'm starting to give up to be honest - if my turbo goes it will be a standard one going on - i'm not going to chase more power as i can't be doing with the pitfalls it leads too
Glad thats fixed bud  :smiley:
You think the mods may have killed the turbo? still got that vibration then?
its a possibility - engine has done nearly 100K and its run the last 18K at much higher boost levels
still got the vibration but the power band it is in appears to be less  :undecided:  need to run it for a few days and see how we go
at this point in time i'm pretty gutted to say the least  :cry: :cry:
Feel for you bud  :sad: Fingers crossed its a cheap fix.
Offline Rhyso
« Reply #51 on: 14 March 2009, 10:13 »
well i've found this thread
http://uk-mkivs.net/forums/p/246330/1594620.aspx#1594620
and after speaking to Mr Dave it sounds like i've over-reacted a little bit - there wasn't huge amounts of oil in the intercooler
just going to keep an eye on it and possibly get the intercooler cleaned out
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #52 on: 14 March 2009, 11:06 »
dunno if you've got access to any but I cleaned my new intercooler out with acetone, worked a treat
I wouldn't worry about a bit of oil in the intercooler, the 1.8T seems to keep the oil rather than burning it off like most turbod cars I've owned/worked on. You'd know about it if the seals/bearings go, I filled up a field with smoke when mine went  :grin:
« Last Edit: 14 March 2009, 18:59 by Wazzzer »
Offline bobbarley
  • I'm kind of a big deal...
« Reply #53 on: 14 March 2009, 18:00 »
Just fitted my coolant temp sensor, WHAT A BLOODY PALAVA!!
Offline richw911
« Reply #54 on: 14 March 2009, 19:05 »
Good news  :wink:
Offline Rhyso
« Reply #55 on: 14 March 2009, 21:01 »
huh??
remove airbox pipe
undo clip
pull out old sensor
stick in new sensor
then connect the plug
took 5 minutes!
Offline Rhyso
« Reply #56 on: 14 March 2009, 21:03 »
Good news  :wink:
yeah for a change - MPG seems to be back to normalish too
whether or not i got used to drving that sh!tty old Saab i don't know but the derv definietly feels much improved and i reckon 95% there :afro:
now where did i put that Stage 2 turbo.........
Offline bobbarley
« Reply #57 on: 14 March 2009, 21:08 »
huh??
remove airbox pipe
undo clip
pull out old sensor
stick in new sensor
took 5 minutes!
I couldn't get the clip to go back in above the sensor to stop it popping straight out.  Took about 10 minutes!
Offline Rhyso
« Reply #58 on: 14 March 2009, 21:11 »
must be different to yours then - the clip pulls DOWN on mine - was able to refit the sensor and then refit the clip - sensor stayed put
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #59 on: 14 March 2009, 21:19 »
good to hear your 95% there with your problems rhys hopefully you'll get to the bottom of it mate  :wink:
2000 Mkiv GTi 1.8T AGU
