Author Topic: they say things fail in 3s......  (Read 12472 times)
Offline Rhyso
Re: they say things fail in 3s......
« Reply #40 on: 12 March 2009, 22:46 »
Damn! That's very annoying!
Not half!! lol
at least my temp gauge seems to work tidy now and i fitted my anni valence so not a wasted evening  :smiley:
Offline T_J_G
« Reply #41 on: 12 March 2009, 22:52 »
Not half!! lol
Just wasted money then ;)
Offline dai-cymru
  • 1989 MK2 16V
« Reply #42 on: 12 March 2009, 23:09 »
INJECTORS?????
need upgraded ones maybe  :undecided:
Offline T_J_G
« Reply #43 on: 12 March 2009, 23:10 »
INJECTORS?????
But (and bear in mind I know nothing about injectors) would they struggle beofre 2500 RPM and then be fine after :S
Offline richw911
« Reply #44 on: 13 March 2009, 00:42 »
Damm whats next to try bud?  :cry:
Offline Rhyso
« Reply #45 on: 13 March 2009, 10:11 »
INJECTORS?????
standard injectors are apparently good for 220bhp from the reading i've done - perhaps its possible they aren't opening up fully under load  :undecided:
unplugged my MAF and took it for a drive - performance was crap so it isn't that although it didn't stall and i didn't have a lumpy idle which i was expecting  :undecided:
i'm pretty sure i've got a boost leak as you can hear the air rushing as the turbo spools, lots of black smoke but then it clears and away i go  :undecided:  had a bit of a poke under the car but need to jack it up which i hope to do later today
i'm fecking stumped to be honest  :cry: :cry:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #46 on: 13 March 2009, 11:17 »
INJECTORS?????
dont tell all the ladies you have a stumpy  :laugh: :laugh:
the injectors could be sticking at low down revs and then getting forced open at higher revs thus why there ok after 2500  :undecided:
Offline Rhyso
« Reply #47 on: 13 March 2009, 22:18 »
UPDATE
big thanks to Dai-Cymru (again!)
solved my boost leak - guess i'll never learn from past mistakes - forgot to swap the o-rings off the old pipe onto the new Forge Pipe  :embarassed:
so boost leak solved BUT possibly another even larger problem spotted - oil in the intercooler  :angry: :cry:
that normally means that a seal is going somewhere and the likely candidate - TURBO  :cry: :cry:
i'm starting to give up to be honest - if my turbo goes it will be a standard one going on - i'm not going to chase more power as i can't be doing with the pitfalls it leads too
Offline richw911
« Reply #48 on: 13 March 2009, 23:20 »
UPDATE
Glad thats fixed bud  :smiley:
You think the mods may have killed the turbo? still got that vibration then?
Offline Rhyso
« Reply #49 on: 13 March 2009, 23:22 »
UPDATE
its a possibility - engine has done nearly 100K and its run the last 18K at much higher boost levels
still got the vibration but the power band it is in appears to be less  :undecided:  need to run it for a few days and see how we go
at this point in time i'm pretty gutted to say the least  :cry: :cry:
