Golf mk2
mk2 16v running issues
Topic: mk2 16v running issues (Read 706 times)
re2
Here all the time
07 March 2009, 13:20 »
the car is new to me but it has a low rev irregularity. Its running regular unleaded and is an '87 on kjet. There are no apparent air leaks and it has a new set of plugs. The revs are rougher between 1500-2500 but it still pulls near enough like id expect. It starts fine and idles well enough
Any ideas?
I plan to take it to Vince but Id like to iron out anything obvious first
Diamond Hell
Serious forum addict
Opinions я Us
Re: mk2 16v running issues
07 March 2009, 13:34 »
New plugs, but how old are the leads, dizzi cap and arm?
Unless you've replaced them then you've not really started on diagnosis.
re2
Here all the time
07 March 2009, 13:49 »
good point but already in place to be swapped for new. Just bought it so Im doing the obvious first and the previous owner had already put the plugs in
any other sugestions?
danny_p
Forum addict
07 March 2009, 15:15 »
once done the basics if that dosent fix it. look at the injectors and compression.
stuck, leacking or cloged injector will make it rough so will low compression on one cylinder
all the VW's have gone bar 1.
Golf mk2
