Author Topic: 16v K-jet fuel pump replacement  (Read 1060 times)
Offline N1xon
« on: 06 March 2009, 22:47 »
what would be the best aftermarket fuel pump to replace the stupid plastic one under the car, the accumulater is also knackered would i need one with an aftermarket pump and would i need a fuel regulator, cheers
Offline Diamond Hell
  • Opinions я Us
Re: 16v K-jet fuel pump replacement
« Reply #1 on: 07 March 2009, 10:24 »
Ummm, why not replace your knackered one with a new direct replacement?
The pump is the right spec for the car and the current one's lasted +15 years.  Why fit a different pump?
Offline danny_p
« Reply #2 on: 07 March 2009, 10:47 »
you need an accumalator end off.   you don't need a peressure reg that on the engine.
but why use aftermarket pump the std item,  the pump itseld sits in the pastic houseing whitch is a resovor full of fuel whitch prevents fuel surge and also it's a bloody powerfull pump.   kjet runs very high fuel pressures compared to efi  and not meany aftermarket pumps will do those pressures
all the VW's have gone bar 1.
« Reply #3 on: 07 March 2009, 17:34 »
replace the housing while you're there, gsf sell it and its a gen vag part too.  then go to vag for 4 new rubber moiunts, nuts, pump mounting screws and seal.
Offline Ben Lessani
« Reply #4 on: 07 March 2009, 23:10 »
There's always loads on eBay, I got mine 4 years ago for about £15 and its run perfect.
Agreed on the above - don't dick about with aftermarket when the right pump is so readily available.
Offline N1xon
« Reply #5 on: 09 March 2009, 20:40 »
cheers for the advice lads, just learning about injection systems as i go ha ha, i was after a small pump so it would be easy to hide (lets just say the car isnt allways on the tarmac ha ha) suppose i could just build a guard to match the sump guard, cheers like !
