Author Topic: golf vr6 big end gone, so new engine time, ar the ecu's locked?  (Read 1479 times)
Offline teeach
as title really please guys, going to buy another engine but just need to know if i need my ecu unlocked or if there are any other problems
cheers
Offline boneybradley
  • Back in a Mk3...
the ecu is coded to the ignition not the engine...just make sure you buy either obd1 or 2 (depending on what you currently have)
Offline Len
Why do you need new engine if its only a big end gone?
Just get the crank ground and new shells!
www.sas.org.uk
www.the-ace.org.uk
  • Back in a Mk3...
I am guessing it much cheaper to buy the full engine than get the crank sorted (to get the chains replaced its about £700!!)
Offline beccasmk3gti
  • golf mk3 gti and a mk3 vr6 182bhp and 223nm
its much cheaper to buy a new engine the cost of replaceing the timing chains its double the cost of another engine
Offline Din
No its not...............  :tongue:
Offline GOD
  • GOD IS A PORN STAR
no its not whats the point when you do some more miles on a second hand engine it will go again
every body vote now http://www.winmeakawasaki.info/.
I would pick up a s/h engine as cheap as poss, replace the chains and give it a full check over before fitting it.
  • Back in a Mk3...
half the cost in doing the chains is the stripping of parts/engine!!....
