Author Topic: Vag com issues  (Read 4512 times)
Offline Voodoo-Music
Vag com issues
« on: 04 March 2009, 19:26 »
Installed vag com today, connected to the car and started a scan, it found 1 problem something to do with the coolent sensor being implausable signal LOL, carried on scanning then it suddenly stopped saying i needed a activation code ?
Not sure why it did that ?
Offline Rhyso
Re: Vag com issues
« Reply #1 on: 04 March 2009, 19:28 »
genuine or Ebay job?
Re: Vag com issues
« Reply #2 on: 04 March 2009, 19:50 »
Well the obd connecotr is a e bay job but the softwar is apparently from the rosstech website !!!!
Offline Rhyso
Re: Vag com issues
« Reply #3 on: 04 March 2009, 20:02 »
yebut its most likely the shareware version NOT the full version which means you can only scan certain modules hence why it probably asked for an activation code
Offline richw911
Re: Vag com issues
« Reply #4 on: 04 March 2009, 20:07 »
It found 1 problem something to do with the coolent sensor being implausable signal
http://www.golfgtiforum.co.uk/index.php?topic=88088.0
Offline Steve_PD
Re: Vag com issues
« Reply #5 on: 04 March 2009, 20:24 »
the free version only scans the engine and fails after the airbag test or ABS test I think
Re: Vag com issues
« Reply #6 on: 04 March 2009, 20:33 »
Your gonna tell me uts expensive for the software ainht ya, great  :sad:
Offline Steve_PD
Re: Vag com issues
« Reply #7 on: 04 March 2009, 20:37 »
you can buy a license for the software you got for $99, for the official lead and updated software IIRC its $400  :undecided:
Offline sambo
Re: Vag com issues
« Reply #8 on: 04 March 2009, 20:47 »
Shareware can scan all modules, but not using autoscan. If you select autoscan it will only scan the first 3.
If you select the modules individually you can scan all of them, just take a bit longer doing it all seperatly  :smiley:
Shareware doesn't allow you to change setting in adaptations though so no beeps  :sad: or autolocks  :angry:
HTH Sam
Sam
AXX power!  ..   Tinkering has started.... :smiley:
Offline Rhyso
Re: Vag com issues
« Reply #9 on: 04 March 2009, 20:51 »
HTH Sam
cheers for clearing that up Sam :afro:
