Author Topic: whats this wire????? pics inside  (Read 3912 times)
Offline Dan Gleebits
« on: 04 March 2009, 10:41 »
is it for the n75  thingybob? what differences would it make running without one?
to be honest if something was plugged in i would want to put it back to how it should be.
if the plug is meant to be left hanging then just ignore me :embarassed:
i have done a search for pics on the n75 but i cant find pics that show how and where its plumbed in.
so any help would be great.
thanx
Offline dai-cymru
  • 1989 MK2 16V
Re: whats this wire????? pics inside
« Reply #1 on: 04 March 2009, 11:26 »
it should plug in to the N75 which is missing and has a bolt in place of it!! I take it your car is running fine without it?
« Reply #2 on: 04 March 2009, 11:50 »
yeah car is running fine, why would someone take the valve off? is it really needed?
thanx
Offline ben1.8T
« Reply #3 on: 04 March 2009, 12:09 »
You need to have a clean up under the bonnet mate  :smiley:
Golf SOLD. Replaced with a Yamaha Raptor 660 quad and loving it. This will be replaced in August with a Raptor 700. Sold the quad now got a Vectra GSI 2.5 V6 and its the nuts.
Brands Hatch massive. MEMBERSHIP ACCEPTED!
« Reply #4 on: 04 March 2009, 12:12 »
to true mate, just want to put every thing back how it should be.
need pics though :wink:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #5 on: 04 March 2009, 12:43 »
ideally you should have the n75 valve fitted as its the boost control valve how/why is yours missing? it looks a bodge  :grin: where the bolt is fastened in the long outlet of the n75 goes into the t.i.p and there are 2 more vacuum hosses which connect to your n75
get it fitted  :wink:
2000 Mkiv GTi 1.8T AGU
  • "1.8T AGU"
« Reply #6 on: 04 March 2009, 12:49 »
see if this helps  :wink:
should give you a general idea  :wink:
« Reply #7 on: 04 March 2009, 12:53 »
this is how i got the car, bodge i will agree,  :grin:
just need to get a valve and find out where the pipes go, why would someone remove this? it does run ok without, but would still prefer it back where it belongs.
« Reply #8 on: 04 March 2009, 12:55 »
thanx for pics :wink:
the thing i cant work out is the 2 pipes coming of it, so its a 3 port valve 1 port into the intake, but the other 2 im unsure.
  • "1.8T AGU"
« Reply #9 on: 04 March 2009, 12:58 »
unless the previous owner had a faulty valve n didnt want to replace it  :grin: madness i paid £45 for mine from vwspeed but dealer or other parts places should be able to source one for you i would advise fitting the std valve back on as you can get different ones to  :wink:
