Author Topic: whats this wire????? pics inside  (Read 3896 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: whats this wire????? pics inside
« Reply #10 on: 04 March 2009, 13:01 »
thanx for pics :wink:
the thing i cant work out is the 2 pipes coming of it, so its a 3 port valve 1 port into the intake, but the other 2 im unsure.
no probs  :wink: yes its a 3 port valve as said the longest pipe fits down into your turbo inlet pipe and you should have two more vac hoses to be fitted one looks straight and the other has a slight right angle bend in it  :wink:
2000 Mkiv GTi 1.8T AGU
Offline Dan Gleebits
« Reply #11 on: 04 March 2009, 13:03 »
1 min pics to come :smiley:
« Reply #12 on: 04 March 2009, 13:10 »
if it is these 2 pipes i take it these need spliting and connecting to the valve, would this run more or less boost doing it this way(pic)??
  • "1.8T AGU"
« Reply #13 on: 04 March 2009, 13:14 »
that pipe needs to be left connected as it is  :huh:
  • "1.8T AGU"
« Reply #14 on: 04 March 2009, 13:17 »
give me 5 mins mate il get a pic of how it should look  :wink:
  • "1.8T AGU"
« Reply #15 on: 04 March 2009, 13:33 »
these are the hoses that are fitted to the n75 valve
the n75 valve
hope this gives you some help in fitting mate  :wink:
« Reply #16 on: 04 March 2009, 13:52 »
so them pipes in my pic do need pulling apart by the looks of it and joining to the valve.
one of the pipes on mine has a dodgy cut so i guess it has been cut down to join together.
so i need the valve and the 2 pipes ideally.
thanx for the pic that helps out a lot, i can now see where to plumb them in :smiley:
  • "1.8T AGU"
« Reply #17 on: 04 March 2009, 14:05 »
looking again at your pics yes the hose needs seperating and you'l need two hoses then to fit to your n75 valve as you say
im sure the dealer will be able to locate the pipe part numbers for you  :laugh:
*pm rhyso on here i beileve that he has ETKA so would prob let you know the part numbers for the hoses as well as the n75 valve*
glad to help you mate hopefully you'l get it sorted  :wink:
« Reply #18 on: 04 March 2009, 14:07 »
cheers mate thanx for your help, mucho appreciated :wink:
  • "1.8T AGU"
« Reply #19 on: 04 March 2009, 14:12 »
no probs :afro: just to say from your pic when you seperate your hoses it looks like you may just need the hose from the pipe with the silver heat sleeving around it  :wink: the other half is from the turbo side of the intercooler and that connects to the middle connection of the n75 valve the hose you want is the one with the slight right angle  :wink:
