Author Topic: Coil Pack Enquiry  (Read 4740 times)
Offline jonnyturbo
Re: Coil Pack Enquiry
« Reply #20 on: 02 March 2009, 21:16 »
well when mine went i got the code sayin missfire in cylinder 1
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #21 on: 03 March 2009, 02:50 »
Right, Ive been sorting out the wiring and have stripped the wiring and cleaned it up and taped it up again, (quite a good job actually  :laugh:)
I no longer have any of the faults that were showing up when I scanned it yesterday - result! BUT i still have the slight misfire....now when the coil packs are playing up do they usually bring up a fault on vag-com?
my performance is still there but there is defo some kind of missing under acceleration - could the timing be out at all?
thanks
generally a faulty coil pack will show up on vag-com just like jonnys did cant remember the code of the top of my head but it referred to misfire-cyl 1
2000 Mkiv GTi 1.8T AGU
Offline chrish22
« Reply #22 on: 22 March 2009, 17:52 »
Sadly this is quite a major loom and its also very expensive from VW, your looking at £400. Go to www.breakeryard.com and put in what part you want, they will email you back with part and price. It cost me £50 all in for mine and turned up next day. Quality  :grin:
Dobber - what description did you put in on breakeryard for this wiring?
Thanks
Offline K666PDP
« Reply #23 on: 23 March 2009, 11:05 »
thought about changing ur plugs? i wouldnt have thought its a coilpack failure as mine went a few weeks ago and gt a missfire cyl02 when the AA ran the codes etc, the loom would be worth looking at but uve done/sorted that,id look at changing the plugs as they could cause the missfire if they are worn/old?
Offline perd999
« Reply #24 on: 23 March 2009, 16:22 »
Just to let u know - it ended up being an exhaust problem, gasket needed replacing at the manifold end which was causing it to blow and a very slight misfire  :shocked: Got a full miltek on its way anyway  :evil: :evil: :evil:
  • "1.8T AGU"
« Reply #25 on: 23 March 2009, 20:29 »
nice one mate glad your sorted  :wink: oh and good work with getting a miltek much better than standard turbo/cat back? res or non res?  :evil:
