Author Topic: 16v conversion running issues  (Read 4668 times)
Offline sparkstu
« on: 28 February 2009, 15:33 »
Hi guys, seem to have suffered a long time with poor tick over, random stalling when coming to a halt. I have no air leaks at all and the car runs sweet when driving. I understand that some 16v's have the idle stabilisation valve and some don't ? I do not have one, all the outlets from the air box are capped off. I can only put these probs down to some sort of vacum issue, can any one shed some more light on these issues ? and are they common on my type of conversion, its been to 2 local garages with no success. Hope some one can help its getting a bit of a pain now  :sick:
Re: 16v conversion running issues
« Reply #1 on: 01 March 2009, 10:26 »
all 16vs have an idle stablisation system, this is why yours stalls and the idle is uneven. you can raise the idle up a bit and put up with it, or fit the isv control unit and parts :)
Offline sparkstu
« Reply #2 on: 01 March 2009, 13:36 »
Cheers for that info  :smiley: Can you shed some light on the parts required and i will get on with it .
« Reply #3 on: 02 March 2009, 09:17 »
behind the centre console on a 16v you find the isv control unit, bouut the size of a packet of fags.  Follow the loom from this and it runs to 2 white plugs just behind the fusebox, plus a black wire to the fusebox itself (ign live)
Pull this bit out then you need to grab the 2 white plugs and remove these from the donor loom, these run to:
temp sensor
red/black wire to spade hanging off coil plug (rev counter)
over-run cutoff valve behind airbox
idle switch
earth on cylinder head
isv
I have a complete 16v engine mangment wiring diagram if you want it
Offline sparkstu
« Reply #4 on: 03 March 2009, 20:12 »
Thanks again !! Did you do your own conversion ? only you seem really clued up. Fancy casting your eye over my engine ?? Am down the M3 in Andover i could wizz up one day. Cheers, Stu :smiley:
« Reply #5 on: 04 March 2009, 08:49 »
as it happens I have just completed the wiring for my MK1 16v cabby ;)
in fact i may even have a spare isv loom kicking about...
i might be around sunday?
Offline Roverdose
  • So long and thanks for all the fish!
« Reply #6 on: 04 March 2009, 20:15 »
mines doing the same, i replaced the ISV and its still the same, RK engineering did my timing and set the idle higher (turning the screw on your throttle body to the left) , he did it when the engine was hot so it doesnt cut out at junctions but its a b!tch to keep at idle in the morning so i sugjest doin it when its cold! the problem only developed in mine when i changed from a 40mm inlet to a 50mm, only thing i havnt done yet is change the gaskets! let me know how it goes as i have a freind who's having the same issue!
« Reply #7 on: 05 March 2009, 10:49 »
does the isv buzz when ign on? is there a second red/black wire to the coil with a spade terminal in it?
Offline sparkstu
« Reply #8 on: 05 March 2009, 17:56 »
Cheers for the offer i am about on sunday as well if convenient, and also should be at no rice on the wednesday if you're going.  :smiley:
« Reply #9 on: 06 March 2009, 14:08 »
canne make sunday now im afraid, not sure I'll be at this months n-r either :(
