Author Topic: 16v conversion running issues  (Read 4669 times)
Offline Stone0311
Re: 16v conversion running issues
« Reply #10 on: 20 March 2009, 16:40 »
behind the centre console on a 16v you find the isv control unit,
Any idea if it is hidden in the same place on a 16v Corrado?
At the point of wiring in my 16v conversion in my mk1 cabby taken from my 16v rado
« Reply #11 on: 22 March 2009, 10:11 »
on a kr corrado its probably behind the console, may be stuffed up behind fusebox i guess?  if you find the 2 white plugs behind the fusebox and follow em back you'll find it. the 2 pin white plug has a white and black wire
Offline Stone0311
« Reply #12 on: 28 March 2009, 19:58 »
rubjonny - Did you install the whole loom with the ISV on? i.e all the other sensors and stuff?
« Reply #13 on: 30 March 2009, 09:38 »
yep the whole lot
