Author Topic: Sub Stopped Working?  (Read 2527 times)
Offline Matt_Mk4
« on: 27 February 2009, 08:22 »
Hi guys,
My sub just randomly stopped working on the way to work this morning
I didn't have it on loud, and it just stopped!
I had a look at the back of it - all the wires were in tact, but the power light wasn't on!
Any ideas?
Offline JC
  • Back in the North.
Re: Sub Stopped Working?
« Reply #1 on: 27 February 2009, 08:25 »
inline fuse  fitted  ?
fuse in the sub ?
remote power feed wire getting any juice to it ?
Offline Matt_Mk4
« Reply #2 on: 27 February 2009, 08:28 »
Inline fuse is fitted - will check all points later
Cheers chuff!
Offline Adam
« Reply #3 on: 27 February 2009, 11:05 »
Get a multimeter and test everything...
Down Hill From Here.
Offline Len
« Reply #4 on: 27 February 2009, 11:07 »
Earth wire! Check its grounded fully!
www.sas.org.uk
www.the-ace.org.uk
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 27 February 2009, 16:30 »
remote wire from the headunit
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Yuley
  • DBP .:R32 :)
« Reply #6 on: 28 February 2009, 02:58 »
+1
and chek all the fuses between the battery and the amp.
Mk3 1.4
To
Astravan
To
Mk4 .:R32   Things just got interesting ;)
Offline MrClifford
  • mk3 golf GTi 8v
« Reply #7 on: 19 March 2009, 03:12 »
had the same problem in my old golf, never found the problem so i took the blasted thing out, saved me a bit of weight and me going def!
coming soon ;)
Offline upfront84
« Reply #8 on: 19 March 2009, 14:19 »
if you've checked all the above it might be that you've blown the rca output on your HU, surprisingly common.
Easy to check this out, just plug a headphone jack to rca lead into the amp and a portable cd/md/mp3 player, switch it all on and see if it works.  If your HU is under warranty it'll be a free repair although you'll probably have to live without it for 2 weeks, if its out of warranty it'll prob cost £50-100 to get it sent away and fixed.
